Results 1 to 3 of 3
    33
    Motor keeps moving
    Seems like every time i run my truck the motor moves. Have to keep reseting it. Any ideas? Oh yea mostly just bashing around on road and front lawn, Seems to happen mostly after a few jumps.
    Thanks
    Chris
    Feb 2010
    El Sobrante, Ca
    7,536
    Do you have the motor mount screw tight enough? Did you have the motor mount bearing go out? You may need an aluminum motor mount or a bad bearing. Also check the adapter that holds the motor mount.
    33
    Im pretty sure it was the bearing, Seemed to be sticking so i opened it up and cleaned it out a bit rolls alot better, Pls see my other post about Bearing help. Also thanks very much for the help
    Chris
