Results 1 to 16 of 16
    Boogie Down BRONX
    369
    Finally Finished My 1st Slash Makeover..
    Wow this was a crazy project... Between trying to work on it after getting off work
    and taking care of my 9 month old son I thought i never finished it. LOL For
    my first makeover i wanted to do the MT slash conversion. You know it gets
    so frustrating when you have no clue on what your doing or if your doing it right.
    I guess thats why they call it a learning experience. But after your done its so
    overwhelming with joy that you'll do it again. Some of the paint didn't come
    out like i wanted it to but im very happy with the end resolts. I also want to
    THANK some of the guys here for there advise and solutions.
    SO HERE IS MY NEW SLASH 4X4 MT.....
    BASH!! BASH!! BASH!! & BASH IT AGAIN!! <CAGE RAGE>
    22
    Wheels and tires look killer. What's the specs on those?
    58
    Looks great! Well done.
    Boogie Down BRONX
    369
    Quote Originally Posted by T-Clyde View Post
    HPI phaltLine with the Tremor wheels 5.5 tall 3.wide 17mm they are hugh i got them off ebay
    as a combo set. when i first got them in the mail i was like WOW.. i hope these fit LOL
    The only thing i had to do was Gear down from 20/52 to 16/52. took them out today
    for the first time ant man do they sound and handle Great.
    Oregon
    69
    Looks sweet, but will those tires clear the wheel wells if you hit a bump (or turn)?
    Niagara Falls, Ontario
    243
    looks sweet, looks kinda like a toy grade rc car
    Feb 2010
    El Sobrante, Ca
    7,068
    Looks great! Good for you! You did an awesome job! Could you share your new parts list?
    Boogie Down BRONX
    369
    Been at the park bashing last nite and this morning... New parts list.
    KingHeadz motor mount w/extra Thunder Tiger 10x19x5mm Ball Bearings
    Traxxas Receiver Box Stampede/Rustler/Bandit * Integy dual motor fans
    STRC Racing Alum Elec Mounting Plate & Heatsink Finned Motor Plate
    STRC Alum Rear & Front Shock Towers * RPM rear body mount * Traxxas Sway Bar Kit
    Stampede front body mount to Give it a little more support to the body
    Nissan TiTan body * MIP X-Duty rear axel * Rpm a-arms left & right rears
    Front & rear STRC hubs and Knuckles * Integy XLS Piggy shocks
    Pro-Line ProTrac Front 17mm Wheel Adapters * STRC battery hold down
    ST Racing Alum Center Main Driveshaft * 2 Gens Ace 3s 40c 500mah Lipos
    B-More
    81
    how did you mount esc?
    St. Louis
    378
    i believe he has a strc esc mount
    Racing in the Past, Present, and Future...MAYBE
    B-More
    81
    will that work with MMP 2200 esc?
    Qld, Australia.
    29
    Quote Originally Posted by reds817 View Post
    If you infact mean the Monster 2200, you will be wanting Traxxas part# TRA5626. This will bolt into the 2 factory holes in the chassis. Personally I am quite happy with it and think it looks rather good, unfortunately I did not receive the 2 secondary screws with mine to attach the On/Off Switch, so.. I just use 2 small Body Clips...
    The MMP's (Mamba Max Pro) have a different ESC Hold Down, I believe it is called "Flappy" or something along those lines, many people on here have them. They can be found easily enough and I am sure people here can give you some feedback on it.
    Goodluck, hope you find what you're looking for!
    -Spec
    Boogie Down BRONX
    369
    I mounted the esc with 3m plastic velcro strip i got it at target it comes in a 3in strip
    I cut it in half perfect fit for the bottom of the esc with the strc mounting plate on
    Piece the other half bottom of the esc. Haven't had any issues very strong stuff and i had
    Some bad wrecks. I tryed the double sticky tape but after the third wreck it popped off.
    With the 3m i can remove it and put it back on..
    Feb 2010
    El Sobrante, Ca
    7,068
    Quote Originally Posted by CAGE410 View Post
    It looks like you did a great job of putting it together! How does the dual fan setup work for you? With the stock setup, it would overload the VXL bec.
    Virginia
    657
    Looks nice! Would look better w/o the tacky side bumpers, they don't do anything now since you have the big tires.
    Boogie Down BRONX
    369
    Quote Originally Posted by Draggin97S10 View Post
    I agree... after looking at it run i thought the same thing lol. Took them off
    Earlier...
    El sob the only reason i connected the fan was cause i thought with those huge
    Tires it would make the motor run hot but since i geared down i don't even
    Need it. Also funny things is when i first hook it up only one fan came on. But
    When i hooked up my mini 3s 1300mah both fans came on. I ran it with one fan
    Running didn'T have any issue with the Rig. So when im switching from one
    3s to another 3 s i pop in the mini 3s for a few minutes just to cool it faster
    Before i pop the next 3s..
