Results 1 to 4 of 4
    94
    slash 4x4 slipper clutch?
    Ok recently received a slash 4x4 needs major rehabbing, i looked online and printed the manual, but does anything hold the slipper assembly forward to the bearing? Thanks! Shim? Or? It looks to me like just rear diff housing
    Feb 2010
    El Sobrante, Ca
    8,132
    Just a little plastic piece that the bearing sits on. I suggest replacing it with an aluminum piece.
    94
    Already ordered that can anyone recommend shocks prefer threaded. Also differential yay or nay?
    Jun 2010
    Miami, Fl
    6,731
    losi ten tt shocks, proline power strokes, if you are into racing you will get the benefit of the diff, if not you don't need it, also the center diff is for 2s max, if you plan to run 3s is not recommended.
