Results 1 to 19 of 19
    Jan 2010
    205
    Spur gear has uneven wear???
    I've been running 15 pinion 38 spur for awhile now. And now all of a sudden I have uneven wear on the spur gear???
    "My Ideas always work sometimes"
    9,848
    Do you have a picture? What do you mean uneven? Such as some teeth are more worn than the others? One half is worn and the other is not? Could be a broken engine mount, bad bearings, or something else...
    Jan 2009
    Beautiful Downtown North Carolina
    1,449
    I would say, check everything associated with gear mesh, including clutch bell bearings. Also, check engine mount area of frame for bending, thats easy because you can see top front of cooling head lower than the rear.
    Master of Traxxas engine longevity....
    1,994
    It could be something broken or mis-aligned like they've said^, or it could be so worn that the tips of the teeth are breaking off.
    Jan 2009
    1,449
    Spur gears are like 3 bucks, so dont sweat a replacement, also, Ebay motor mounts are extremely cheap!
    Jan 2010
    205
    just before the spur went on me.....I lost the 2 screws that hold the exhaust header to the crankcase.
    Jan 2010
    205
    thanx for the info gents...
    Quote Originally Posted by cadmanslayer46 View Post
    Yup cleaned out the LHS on spurs right after (3) 2-38t and a 40t....not sure I need a a motor mount...yet.
    Jan 2009
    1,449
    Alot of times, you wont even notice engine mount broken, my experience has been that the right rear corner breaks off.....
    carolina
    125
    I may be wrong but judging by what i see in that picture it looks as though its partially stripped to me, not that its worn uneven. Just my opinion
    9,848
    I agree. Looks stripped.
    1,994
    Yup, something moved under power and stripped half of it.
    carolina
    125
    when you install a new spur gear, for just a little extra insurance i use blue loctite on all of my engine mount screws. And make sure you have the star washers inbetween the mount and the cradle, if not that could have caused you're slip.
    1,994
    The star washers can go between the bolt head and cradle, not between the mount and cradle. I know it shows different in the exploded view, but it's not good.
    carolina
    125
    Quote Originally Posted by lubecakes View Post
    Lube im not sure i understand exactly what you are saying. I think your saying put the star washer on the outside?. What do you run between the cradle and mount.
    1,994
    I prefer the cradle and mount to be tight against each other for strength. Then I use the washer on the bolt head.
    May 2007
    West Coast, Fl
    2,114
    I disagree, the star washer should be against the mount and the cradle. There is a relief there that is made for it and that is where you will need to prevent movement. I also do not use locktite on my engine screws. They are already set up with compression washers and work fine without it. Chassis flex can cause this as well and might want to consider a better brace.
    RBMods
    carolina
    125
    that's what I thought you were talking about lube. That makes sense I just chose to do the other lol. I have a system that works for me if you know what I mean. And if it weren't for loctite I would never be able to run much as my engine screws will back out if I dont
    May 2007
    West Coast, Fl
    2,114
    If your going to use locktite and its always good to do what works for you, it would be good to clean off the old everytime or it will cause slop eventually in the holes as the mount is soft cast aluminum.
    RBMods
    carolina
    125
    yea I agree. I have to use bunches of that stuff though. I put it on my wheels,engine,roll hoop, lots of places I have to have it
