Results 1 to 9 of 9
    New Hampton, Iowa
    311
    Question center diff? confused...
    alright im on projectace revo.going to be putting in the center diff... to have the center diff do I have to have the rear brake upgrade? also can I have the foc and the center diff?? whats a good weight oil for racing on a very dry loose track? thanks
    http://www.youtube.com/user/dennerracingteamdrt
    Tanker 822
    9,578
    With a CD, if you want braking to the rear tires you need the rear brake pads and rotor. The CD is a FOC only that it can split the power between the front and rear whereas the FOC is just a gear on the output shaft.
    New Hampton, Iowa
    311
    so if i put the cvd in, i wont need the foc but for rear braking ill also need the rear brake pads and rotor. Correct?
    1,994
    You'll need rear brakes for the CD and only one brake with a FOC.
    May 2007
    West Coast, Fl
    2,114
    The FOC comes with the CD and has to be used. The rear brakes are also a must with the CD and for racing you will want rear brakes anyway. Before you even install the CD change the diff to heavier oil, 500K is what you will want for the best results.
    RBMods
    carolina
    125
    pnt are you sure man? I don't think it comes in the foc kit
    Jan 2009
    Beautiful Downtown North Carolina
    1,449
    If I remember right, installing the center diff, is in effect a forward only conversion, in and of itself.......
    Master of Traxxas engine longevity....
    May 2007
    West Coast, Fl
    2,114
    The FOC comes with the CD kit and is needed to operate. That is the gear that is in contact with the CD gear. Both are wide gears with alot of contact area. When you buy the FOC by itself it comes with its own output shaft which I believe does not accept the rear brake setup. In the CD kit I believe it comes with the gear only and installs with a grub screw pin on the shaft that is there.
    http://www.google.com/products/catal...d=0CEMQ8wIwAw#
    RBMods
    1,994
    They both come with two gears. One goes on the primary shaft and is used to drive the output shaft.
