+ Reply to Thread
Results 1 to 11 of 11
    Oct 2011
    TENNESSEE
    364
    My take on the slice 4x
    So i bought the chassis from jayjanek from the forum here and he was having a problem with the center diff binding i have a slice B2 on my 2wd slash so i got the 4x from him and had the same problem with the chassis that jay did but it was a very simple fix i did a little grinding with the dremal around where the diff gear set to widen that area and also ground the area where the motor shaft set and it WORKS GREAT IMO this is a very good mod for the money i took it to the track last night and it handles SWEET it jumps 1000 times better in the sence that it dont drop the nose like it did on the stock chassis so overall i would give this kit a 9 out of 10 for making this a WAY MORE race ready truck
    MINE ARE FASTER THAN GPS!!!
    Oct 2011
    TENNESSEE
    364
    and i will add this chassis is very strong alot less chassis flex than with the stock pan
    Sep 2009
    Saint-Jean sur Richelieu, Quebec
    70
    Can you post pics of what you did, it might help others who have or thinking about this chassis (me)
    Oct 2011
    TENNESSEE
    364
    here is the cut area around the pinion the other spot i cant get a pic of but is a very simple to figure out when you get the chassis here is a pic from the instructions its the part that is around the spur gear
    Oct 2011
    MISSOURI
    390
    but didnt he have problems with bending the drive shaft?
    EFFORT EQUALS RESULTS
    Sep 2009
    70
    Is it just me or there isn't anything holding the top of the motor mount to the frame ?
    that would probably cause a bent drive tube on rough landing.
    Jul 2011
    514
    Looks great man. Very nice to talk to you enjoy and remember drive it like you stole it. Lol
    4x4 Slash 5.5 Big Block
    Oct 2011
    MISSOURI
    390
    but wait i wanna know before i buy one of these ,was the problem for jay janak bending drive shafts or was ur mod fix the problem .
    Waterloo Ontario
    44
    reposted with quote below
    Waterloo Ontario
    44
    Quote Originally Posted by Goglu2 View Post
    No there isn't. We assembled a friends and we found that to be the weak link in the chassis. We added a tab to join to the center hole on the top of the motor mount. If you were running an upgraded mount I think it wouldn't be quite so bad but with stock mount it flexes all over. Once we added that all was good. The performance gain is huge.
    One improvement would be to ditch the screws and tapped holes in plastic spacers and go with bolt through with nut.
    Oct 2011
    TENNESSEE
    364
    no it wasnt a bent shaft it was a binding issue with the driveline and yes there is mounting for the motor mount at the top the holes are pre drilled it is a very good chassis
