Results 1 to 13 of 13
    38
    2s lipos vs nimh
    I bought some 3s lipos this weekend and they are just way too powerful and get the mottor extremely hot. So should i stick wtih my nimh batteries, or try 2 cell lipos? Ad whats the difference in performance between those two?
    Nov 2011
    SoCal
    172
    I just started using 2 cell and I detected added power along with greater run times.
    Dec 2001
    Dallas, TX
    669
    If your motor is getting hot, then you need to try a smaller pinion gear. The difference is 2s lipos are 7.4 volts and 3s are 11.1 volts.
    Lilydale, Victoria, Australia
    2,845
    Gear the car correctly and you will be fine on 3s
    Start with 11/54
    If geared the same 3s lipo will be 50% faster than 2s
    or if you like 2s will be 66% as fast as 3s
    Cheers
    Slash Platinum
    Nov 2011
    SoCal
    172
    Quote Originally Posted by crusey View Post
    Start with 11/54
    Cheers
    Crusey can you comment on how much faster you think 2's are over the stock nimhs?
    38
    Oh in the last sentence i meant difference between 2s lipos and 7 cell nimh. By the way i stripped the grub gear that holds on the pinion
    2,845
    Volts = Speed
    2s lipo fully charged - 8.4v
    6 cell nimh fully charged - 9v
    7 cell nimh fully charged - 10.15v
    The nimh pack may actually be faster for the first speed run
    As soon as the voltage of the nimh pack drops its a no contest win to the lipo
    Lipos maintain a higher voltage under load
    Lipos will allow more amps to be drawn throughput the duration of the pack, meaning more consistent power
    Cheers
    Slash Platinum
    38
    And an 18 tooth pinion is stuck on there
    38
    crusey i think your volts are way off.
    i know 2slipo = 7.4
    6 cell nimh =7.2
    7 cell nimh= 8.4
    2,845
    Why is it stuck ?
    Drill the grub screw out and get it off if you have to
    Thats why you are having heat issues
    Even with stock 13/54 gearing the motor will get hot when bashing
    Cheers
    Slash Platinum
    Nov 2011
    SoCal
    172
    Thanks you
    2,845
    Quote Originally Posted by johnb1234 View Post
    i know 2slipo = 7.4
    6 cell nimh =7.2
    7 cell nimh= 8.4
    My volts are correct mate
    The voltages you listed are nominal only
    A lipo cell is 4.2v fully charged straight off the charger
    A nimh cell is 1.45v fully charged straight off the charger
    Cheers
    Slash Platinum
    38
    okay i gotcha now
