Results 1 to 15 of 15
    254
    2-lube or not 2-lube, CV joints, pivots? anything? just clean? What should be lubed?
    Should I lubricate moving parts on traxxas 4x4?
    Dry lube / teflon spray?
    Grease & clean?
    I understand that wet grease / oil lube can attract dust and increase wear.
    Do I just clean pivot points?
    Dry teflon lube?
    Lube some stuff and not other stuff?
    What should be lubed? How?
    Warning: BAD PERSON-10pt infraction for trolling
    El Sobrante, Ca
    8,120
    The only parts I lube are the diff gears and bearings.
    Jun 2010
    Miami, Fl
    6,731
    I started to use Graphite dry lube, and I'm very happy with i, it covers real good the parts and it doesn't attract dirt.
    254
    Thanks for the reference on graphite.
    I think my local RC shop may have some, but if they don't, I may do Hobby-Lobby because they have BoyScouts derby car graphite lube.
    Is one graphite lube any better than others?
    UK
    1,936
    dry lube for exposed areas such as ball ends an pivot balls. Bearing oil for bearings (especially motor bearings other are pretty well sealed). Then just diff lube for diffs and shock oil for shocks
    Does more $ = More fun?
    Rustler VXL
    254
    Thanks again. I had a few people tell me "no lube at all" but they didn't offer the replace pre-worn parts either.
    Aug 2010
    Port orange, Florida
    568
    I use dry lube made by PB blaster I spray the heck out of the whole truck leaves a white residue than can be wiped off but works so well, keeps a lot of dirt from sticking and keeps all parts rust free and parts moving freely great investment get it at auto parts store or home depot
    254
    Quote Originally Posted by snookerd1206 View Post
    PB Blaster... Thanks I'll check it out.
    El Sobrante, Ca
    8,120
    Quote Originally Posted by KewlToy View Post
    I've never had any rod ends or such wear out. Mine are all over two years old! Nothing has worn, still like New. If graphite works, go for it but mine is still great without anything
    254
    Wow, that makes me worry less...
    I ride dirt bikes and 4-wheelers.... lack-lube is bad on those.....
    North Florida
    676
    most of those joints aren't plastic to metal though
    sent from my BAMFed Thunderbolt
    fix, run, break, repeat
    El Sobrante, Ca
    8,120
    Good, there is absolutely no reason to worry
    Laredo TX/ Reno NV/ Palm Coast, FL
    272
    Blaster works awesome !
    626
    try some chain lube on cvds. it stops the squeek and doesnt attract much.....well you know the drill
    254
    Thanks again guys
