Results 1 to 4 of 4
    112
    Center driveshaft question
    Just wondering how much the center driveshaft should be able to move front to back? It looks like the connectors at each end have 1/4" of spline exposed which allow the shaft to slide back and forth leaving very little engaged at times.
    Niagara Falls, Ontario
    243
    mine does the same, i thinks its fine
    Sep 2010
    Houston, TX/South Texas
    446
    Slide the rear splined hub as far forward as you can while maintaining good contact with the slipper shaft. It will minimize the sliding and maximize spline engagement.
    ERBE Summit E-Slayer
    EMBE
    Rustler
    P4DE Sl4sh
    Feb 2010
    El Sobrante, Ca
    5,197
    Quote Originally Posted by tbonemcniel View Post
    I do not recommend doing this! It makes it so the driveshaft wobbles. At high speeds it will throw your truck off. We talked about this maybe eighteen months ago! The driveshaft has a lot of play in it. If you hit anything at speed head on, it has less possibility of bending the driveshaft when the chassis flexes. If it were a tight fit, anytime you hit something head on you would have to replace your driveshaft.
    Slash 4x4 SCT 2400
    Slash Ultimate MMP 2400
