Results 1 to 11 of 11
Thread: MIP Care
    St. Louis
    379
    MIP Care
    I am buying a set of MIP's for my slash and i have read several different problems with them, but i am getting the MMP2400 and i do not want to deal with the driveshafts breaking. My main questions are, what should i loctite? What is the pin that everyone says falls out?( so i can watch for that ) and what are maintnence for them?
    Thank you for your inputs
    Racing in the Past, Present, and Future...MAYBE
    Wichita, Kansas
    251
    I have the same questions
    Nov 2011
    115
    I have a 2400 running on 4s only on monstertruck tires and I have not had any problems with the mip x-dutys yet.
    El Sobrante, Ca
    7,711
    Loctite all the screws. I have had mine for a year, never lost anything. I suggest blue loctite. That way if you need to take them apart, its not so bad. Just make sure to let them sit over night before you use them. The loctite needs to dry.
    90
    As stated in the thread above this one, make sure the flat spot on the pin is facing where the set screw goes through! (it's hard to notice but it's there).
    Boogie Down BRONX
    369
    Quote Originally Posted by joffadan View Post
    +1111 on the Flat spot.. I made that mistake, didnt notices it till i was looking at the diagram and saw the flat section
    had to break the loctite seal and wait another day before i could run my slash.. UGGHH i guess thats how you learn..
    BASH!! BASH!! BASH!! & BASH IT AGAIN!! <CAGE RAGE>
    St. Louis
    379
    i guess i will have to wait until they get here because i have no idea what the flat spot is! haha
    Boogie Down BRONX
    369
    LOL Its the same flat spot that is on your shaft of your motor where the pinion Goes. If the screw
    is tighten on the rounded side it will always come loose from the vibration of the motor.
    rounded edges nothing to keep it in place But when you screw it into the flat spot it cant go anywhere
    especialy when you use blue loctite.. you can also go to MIP website to see the diagram..
    St. Louis
    379
    oh no i wasnt talking about the motor i was talking about the mips. but yeah i know that haha
    Nov 2011
    Western Kentucky
    792
    I just installed these I had to go to their site to figure out the assembly follow it step by step and defiantly use loctite on the set screws
    ERBE,Losi 8ight,Slash 4X4
    Boogie Down BRONX
    369
    LOL... MIPs axels is what im talking about i was using the motor shaft as an example..
    sorry to confuse you..
