hey guys my truck is having a lot of sloppyness up front and i was wondering how to fix it? i have the strc aluminum bell crank set rpm arms and traxxas aluminum front c hubs and knuckles that are about a year and a half old
slash 4x4 and a blast on steroids
how are the bearings in the front?
they seem fine. if they arent i have a set of boca bearings waiting to be put in. i was just gonna wait till they went out. how can i tell if they are bad?
I would check the steering blocks. I just replaced mine with GH racing and 90% of the slop is gone. How can you tell if a bearing is bad? Take the bear hold with your finger and roll the outer case if you have resistance, binding or if you hear like crunching nose you should replace the bearing.
4x4 Slash 5.5 Big Block
ok thanks. are the GH blocks expensive?
