drive shafts and pinion gear question
anyone ever used the ST Racing Concepts Heat Treated Steel Driveshaft Kit? If so are they as good as traxxas heavy duty driveshafts from the sl4sh? also do regular traxxas brand pinions fit on the castle creations NC 1410 3800 KV motor which has 1/8th inch shaft? or would the robinson racing 1/8th inch bore ones be a better idea?
- You may not post replies
- You may not edit your posts
Forum Rules
