    Nov 2011
    46
    Unhappy diff oil or grease???
    hey guys i recently disassembled my rear-diffs because the bearings were damaged.
    When i opened the the diff plastic housing i saw only grease inside. which is weird because
    i heard there's suppose to be diff-oil there.
    can someone please explain if i need to put only grease or do i need to buy diff-oil?
    Tanker 822
    9,676
    What T-Maxx do you have?
    Latitude:N 37 15' 47.0002" Longitude:W 115 47' 34.8713"
    2,435
    if its a sealed diff then you put in diff lube, i use 50k in the front and 30k in the rear on my e-maxx spec sealed diffs, on the pinion and ring gear you still just use grease
    if your diffs are not sealed diffs, which most tmaxx's arent, then use grease on all of it....
    youll know if its a sealed diff itll have a rubber seal imbetween the ring gear and the diff housing...
    Traxxas is good, but so are other Manus
    Jan 2001
    Fresno, CA
    2,008
    Do you mean there is grease in the diff CUP or the diff HOUSING the housing there should be grease if your diff cup is a sealed unit there should be oil fluid in there. If it is not a sealed unit the grease is fine al around
    Sent from my secret hiding place AKA the garage.
    3.3 t-maxx, O.S. .18TM t-maxx, HV brushless e-maxx
    2,435
    Quote Originally Posted by likametal View Post
    yeah i meant diff cup not housing
    Nov 2011
    46
    aaah now i see the diff cup
    so there is diff-oil inside. i didn't dissemble this part because i only changed the
    bearing on the side of the center diff drive.
    thanks allot guys
    Usquam sed hic
    1,568
    Yeah I once put 50,000wt silicone diff lube into my unsealed differentials - big mess.
    Matthew 7:7
    nunya business
    239
    Quote Originally Posted by 1979chevy. View Post
    try that with 3in1 when i was still new to the hobby! wandering why i still had oil all over my hands! what a mess!
    my life sucks
