    65
    Lightbulb Stones getting into the spur gear area? I have the solution! I think....
    Hi guys I was having a major problem about little stones tearing up the spur, and I couldnt understand how they were getting in there... And just this morning, I seem to have fixed the problem! All I did was put a bit of electrical tape over opening for the locknut used to hold the motor mounting screw in place (directly in front of the gear cover screw), and it seems to have worked like a charm! So if any of you guys have been having this problem, try this, and it might just be the problem!
    Posted in Australia, the country Down-Under
    El Sobrante, Ca
    7,562
    My solution was to take the cover off. It's been off for a year and a half. It seems without the cover, things can fly out of the gear area instead of getting stuck in the gears.
    65
    Well that could work too, but I found that doing that would cause grit to get into the grease for the rear diff, causing it to seize up... So I put it back on, and well, lets just say it worked like a charm...
    Oct 2011
    MISSOURI
    390
    R u guys runnin the clear cover . My black cover has never gave me this problem
    EFFORT EQUALS RESULTS
    65
    No, I am running the stock black gear cover... Just went out with it again, and still no problems!
    65
    Quote Originally Posted by HELLO_ANGEL1 View Post
    apart from motor temps/gearing choice
    El Sobrante, Ca
    7,562
    Like I said, I have run without it for well over a year. No dirt in the diff, no problems at all. I just don't get pebbles caught in my gears.
