+ Reply to Thread
    111
    Batterie, esc, or motor
    Second post in 2 days, yikes. So this kind of fallows up with my last post "rookie needs help." My car is a slash converted to merv so I might have screwed something up. So my last problem was fixed when I took my bulkhead apart and and put it back together. now I have a problem where I don't have a lot of power and if i keep a steady throttle the car slows to a stop and stutters like I have a really low throttle, I let of the throttle and it works again but still with low power.
    -totally confused rookie
    Feb 2002
    4,514
    did you convert to merv gearing?
    cant tell exactly what yor problem is... but things to check... check your slipper clutch
    is the esc blinking anything ?
    Love how Noobs ask a ?, then say you're wrong
    111
    Is the transmission different? or just the spur/pinion? Differential gearing?
    111
    The esc has blinked in the past due to heat not anything else.
