    899
    Can someone better explain the 2 a-arm holes
    I tried reading about them, but I didn't understand what bump steer is etc.
    Just wondering why there are 2 positions the pin in the a-arms can slide into and the pros/cons , thx
    Jun 2003
    We-Go, Chicago, IL
    2,708
    The lower pin holes can change the roll center of the truck and improve the handling.
    Aw, Biscuits!
    Jul 2007
    Rc Room
    1,484
    Bump steer and roll center are two different things and are controlled different I believe.
    Bump steer is when you compress the suspension and the camber angle changes throughout the wheels vertical travel=bad. This is controlled but seldom used by flipping the ball studs over. I think??
    Roll center(moving the pins) effects the center of gravity. I'm not for sure on the rest.
