Results 1 to 14 of 14
    126
    Twitching Throttle Servo
    Hey guys I have an original 4910 T-Maxx and when I turn the truck on the throttle servo constantly twitches. It will center wherever I have the trim set, but moves rapidly back and forth about five degrees in each direction. If I apply throttle it will also twitch at any setting I move the servo to. If I switch the channels on the reciever neither servo twitches at all so I don't know how to tell if it is a servo problem or a transmitter problem. Has anyone had this problem before?
    Latitude:N 37 15' 47.0002" Longitude:W 115 47' 34.8713"
    2,435
    ive never had that issue but if i was to guess id say servo, and the throttle servo is cheap to replace, also my lhs would take it back if it didnt work.... not sure about yours... i hate wierd electrical issues esp on real vehicles, there the worst
    Traxxas is good, but so are other Manus
    Lehigh Valley PA
    78
    wvaughn: I have the exact the same truck but my MAXX is a nitro & I have not experenced any twitching @ all I always make shure Fresh Batt's are used & my servo's are fine NO GLITCHING try installing fresh batt's reset everything & you should be ok.
    126
    I never even thought, but I just did the FOC kit on the truck and removed a working 2018 servo that was previously used to shift from forward to reverse and vice versa. Is this servo adequate to power the throttle and brakes? It currently has a Traxxas 2055 high torque servo, but as I mentioned it has been acting up a lot. Ill go switch them out and see what happens.
    Olmsted Falls, Ohio
    414
    thje 2055 i 86oz in torque, the 2018 is 72 oz ,so im not sure if youll get your full throttle, but you may :P
    2,435
    yes the 2018 will work fine, its what i use on both my tmaxx's throttle/ brakes, it fully opens the throttle no problem and slams my brakes real nicly..... a 2055 is rated at 80oz/in, and a 2018 is 42oz-in...
    still more then enouph for a throttle/brake servo, btw the 2055 is technically a high torque steering servo, over kill for a throttle/brake...
    126
    It wasnt really the throttle I was worried about haha. I figured that the brakes would be what take all the power.
    2,435
    wierd, i stand corrected, haha, but id tend to not agree with traxxas on the 2018, if i put that on my steering its way more then a 14oz/in difference from the 2055, and everyone but traxxas lists it as 42oz/in which makes more sense to me
    Olmsted Falls, Ohio
    414
    yea, i jut go by what it says, but imo, the steering sucks! i need a new steering servo D:
    2,435
    Quote Originally Posted by naturalstrike View Post
    yes even the steering servo 2055 is not a great servo, i went with a s3305, its 125oz/in metal geared, and it ripps my tires fully left and right when the vehicle is not moving....
    Olmsted Falls, Ohio
    414
    how much did you pay?
    2,435
    i got mine at my lhs for $35, and its a direct fit to a traxxas horn or servo saver...
    btw the only thing i can think why traxxas lists there servos as higher oz/in is that they are rating it being used with 6volts, not sure on this but that would make sense then...
    Olmsted Falls, Ohio
    414
    oh thats not too bad, and yea makes sense
