Results 1 to 7 of 7
Thread: Stripped Screws
    98
    Stripped Screws
    Im trying to replace my aluminum front lower A Arms with new RPM's and the screw that holds the shock to the arm is completely stripped out. And I mean really bad... like the philips head is a circle...
    does anyone have any tips to get screws like this out short of drilling it out? I'd like to keep these arms for another time
    Thanks!
    -Off the Jump!!-
    CRASH
    Feb 2010
    Brewster ma.
    701
    Easy outs. My only suggestion. You can get a cheap set from a local hardware store. I got some from sears just for my nitro trucks.
    Sent from my workbench
    Keep the shiny side up!
    Nova Scotia (Eh!)
    422
    Use a dremel or cutting wheel and make a slot so you can use flat-head screwdriver to get it out.
    back
    2,435
    Quote Originally Posted by maxidodies View Post
    +1 this is what i do....
    Victoria B.C Canada
    5,191
    If you can't get a dremel in jb weld a old Allen key on it,If that doesn't work at least There will be material to cut a slot in or maybe grab with vice grips.Is it. Loc tited if so soldering iron on the head of the screw to soften the loctite. Couple more ideas at least
    Mountains cant stop me
    they have tried
    98
    Nope no locktite. Ill try cutting it with a dremel
    -Off the Jump!!-
    CRASH
    Cocoa Florida
    3,999
    Get a "Micro GrabIt Bit", best ever easy out for stripped screws & can be found for around $10 in your local hardware store.
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
