Page 6 of 8 FirstFirst ... 4 5 6 7 8 LastLast
Results 201 to 240 of 288
  1. #201
    10,212
    Use red...
    LETS GO PENS!!!!
  2. #202
    McHenry, Illinois
    648
    Use red...
    I just had to drill out a pin through an integy XHD shaft at the gear shaft! Used Red... Maybe Blue in that location next time!
  3. #203
    San Jose, California
    98
    Quote Originally Posted by beetroot72 View Post
    I have plenty of both. I do engine and transmission work on full sized cars too.
  4. #204
    Liverpool, New York
    231
    After driving for a full 3s 5000Mah battery pack. Found that I only had three wheel drive. Broken right front axle stub. Sheared off the ears and lost, but then found axle shaft half on the ground. It is possible to have caused any damage to the diff since there was no load on one side?
  5. #205
    Okanagan Valley B.C.
    674
    Quote Originally Posted by ramflames View Post
    Is it possible to have caused any damage to the diff since there was no load on one side?
    Chances are you did no damage but it sounds like you need to upgrade from plastic half shafts to something stronger especially if you plan on running 3s
  6. #206
    674
    +1 for the Blue there
  7. #207
    Liverpool, New York
    231
    Quote Originally Posted by NITR0 newbie View Post
    Yup. I have MIP Xdutyes in the rear but have not forked over $60 bucks for the front yet. I'll tell you.
    There was no signs of wear to the fronts. No twisting or egging. just snapped!
  8. #208
    Berglangenbach, Germany
    31
    1x spur gear in 10 minutes
  9. #209
    21
    I had MIPs in the rear for a while, just broke my second front stock axel. I got a set of front MIPs from eBay for $50 shipped. Crazy to spend $100 just upgrading the axels but the MIPs are top quality and a replacement stock axel is $10 each.
  10. #210
    674
    MIP's are awsome and I just wish I took more pics but I use a "modded' set of Rustler rears to fit the sock length a-arms which are the same ones used on the pro-trac kits.
    I just think it has less axle slop this way but that that's jmo.
    If you look at the left side you can see what it looks like in running condition.
  11. #211
    United Kingdom
    555
    To date :
    2x spur gear
    1x wheel bearing
    1x rear shaft (upgrade to Tekno)
    1x Wheelie bar
    Stripped the rear wheelie bar mount screw holes but bodged together with slightly longer screws and washers.
  12. #212
    69
    Not a thing yet again close to 20 packs now!
  13. #213
    98
    Last night my son broke a front stub axle and I thought I has stripped a sput gear. Turned out a rock got stuck netween the slipper adjustment nut and chassis. It completly loosened the slipper clutch to the point where it wouldnt move at all.
    But we had a really good time until we couldnt drive anymore. As we were walking back home, carrying our Stampedes, we joked that we need to build an R/C tow truck for when this kind of thing happens.
  14. #214
    31
    Bumper screws snapped right in two (x 2). Thanks for cheap weak points
  15. #215
    Liverpool, New York
    231
    NOTHING, I'm still waiting for parts to come in to fix a MIP Xduty shaft. There for my P4de is just collecting dust on the shelf.
  16. #216
    8
    Playing at the local bike park, hit a 6 foot tall table top, got about 12 ft of air, traveled about 25 feet and came down front bumper first into the next ramp. Snapped the battery post off at the threads and tossed my 3's battery through the body..... So nothing major today.
  17. #217
    Williamsport Pa
    351
    Piston chipped and a small fragment got lodge inside the case on my 3.3 jato. Took it to LHS and he said he never saw that before. Called support and they said...send it in. Keep in mind that I always run a bit on the rich side with plenty of smoke. Well, here's the kick in the pants. Traxxas won't replace it, nor will they send my old engine back. So much for brand loyal !
  18. #218
    Liverpool, New York
    231
    I was driving my P4de down my street at full speed. My son was driving my P2de, he came across the street right into the path of my P4de. BAM!!!!!! My P4de survived. Must be the RPM A-Arms. The P2de suffered a broken right front tie rod. Totally fixable. Surprised the damage was not more than it was.
  19. #219
    Wales in the UK
    1,925
    My rear bearing are getting cruchy so time for new ones...peace
  20. #220
    Wales in the UK
    1,925
    Thats because its traxxas tough
  21. #221
    Rotterdam
    50
    lost all drive to the car, after inspection found out that I broke the pin that drives the slipper...
  22. #222
    674
    Found a new weak point in the drive line, seems after doing some 3s speed runs on the beach in damp sand with trenchers, mip's and slipper set to full tight I managed to rip the screws out of the diff carrier that attach the ring gear luckily all the gears were ok just had to replace the screws and carrier case.
  23. #223
    Perham,mn
    61
    Learned that when the bearing inside the slipper goes bad it loosens up so no drive then
  24. #224
    Salisbury, NC
    633
    Quote Originally Posted by Strykeviper View Post
    all I get is a whine and no movement out of the motor shaft. Can barely turn the pinion by hand.
    Sounds like you snapped the rotor shaft inside the can. Been there, done that. Time for exchange.
  25. #225
    674
    Nothing broke on my pede which is more than I can say for my buddy's rustler after some speed runs on the beach today lol
  26. #226
    Salisbury, NC
    633
    Quote Originally Posted by moody03svt View Post
    Thanks for info, I think. I will check over the manual again. Is the ring gear casing the same as the rear diff cover? I removed the cover which exposed the ring gears and there was grease all over inside but no fluid. Is the fluid inside where the large gear is still attached to the diff cover?
    Sorry to hijack thread!
    There's supposed to be grease in the dif cases f/r. The fluid is 30K oil in the front dif housing (round black piece) which is inside the dif case. The rear dif is filled with grease. I've switched my rear dif to 100K fluid to get the positraction effect. Some people use "horsie grease" or STP. The black grease looks like "sludge" after a while.
  27. #227
    Salisbury, NC
    633
    Quote Originally Posted by gtlightning98 View Post
    That was hard for me too, and I put off the fronts as long as I could. In retrospect, it's probably the best $100 I've ever spent on it and greatly improved uptime. By that I mean more runs before you have to fix anything, even on 3S every day.
  28. #228
    674
    Did some more beach running yesterday till I snapped another hpi screw/pin on one of my rear mip's, makes me wonder if ther is a better pin out there cause I been breaking these often on 3s.
  29. #229
    Vancouver BC Canada
    178
    I broke 3 stock driveshafts within an hour of running
  30. #230
    Salisbury, NC
    633
    I think I burned a bearing in my 10 day old Velineon. Went to throttle after a rollover and heard a crunch like I had stripped a spur gear. I did strip the spur gear and after I got it changed I could not roll the truck. Took out the slipper clutch assembly and all I get is a whine and no movement out of the motor shaft. Can barely turn the pinion by hand.
    At least I have no downtime. I didn't want to wait when I separated the magnet on my original motor. Sent it in for replacement and bought a new one from the lhs. The new one from Traxxas came in today
    And the one I bought at the lhs is going out for replacement tomorrow
    Guess I was wrong about downtime. The seized velineon took my VXL-3S with it
    I've seized a couple of motors, but the ESC must have shut itself down like it should. You might give Traxxas a call as it may be bad and not work (shut down when it should) with your new motor if you overcook it.
  31. #231
    Young, AZ
    44
    Broke both my steering blocks in the front!!!
  32. #232
    Houston Texas
    156
    Todays payday so i might just go break the bank at my LHS today. Hmmm... What do i want? I don't know...EVERYTHING!!!
    But so far i haven't actually broke anything.
    Rustler + Lipo + Dirt = FUN!
  33. #233
    Portland OR
    381
    Drove 45 min to a spot ran 3min and it totally shut down cause the mmp ground wire broke off right next to the solder. And I brought 4 charged lipos!
  34. #234
    19
    Real wheel hex pin snapped on both sides of the pin!
    IMG_1662 by jv2012ebay, on Flickr
  35. #235
    6
    Noobie basher here with my first break after 5 packs
    absolutely demolished my wheelie bar 4 breaks and the wheel broke off.. super glued the creap out of it and now it's a wheelie bar with no wheels...
    Also lost a body pin and the back pin slots are getting pretty beat up
  36. #236
    6
    I smoked my esc ( started smoking ) 120 bucks down he drian i also snaped a stock bearing holder by runing my truck over with a golf cart only thing that broke tho O and i aslo siesed up a motor 70 bucks
  37. #237
    The Mitten
    1,633
    Quote Originally Posted by Donovan Meacham View Post
    Its most likely a bearing internally. Just get a VXL motor rebuild kit. ~$8
    Everything overpowered...
  38. #238
    Salisbury, NC
    633
    Destroyed another Pro-Line body, that makes 5 now.
    At least my Slash rear bumper helped it to last a little longer and with the wheelie bar wheels on it, it seems a little more practical than the stock Stampede wheelie bar.
    Keep the comments coming guys and gals.
    Are you reinforcing them around the body mounts and weak points? I got 11 months out of my stock body that I run every day and hit several telephone poles at high speed, etc. I'm now running a Raptor body now that has some cracks around the roof and one in front from a telephone pole that's been repaired. I put a thin steel plate in the bed of the stock body (underneath) so that the mounting pins actually went through that metal. I think that's why it lasted so long.
  39. #239
    United Kingdom
    555
    Broke my first A-arm!
  40. #240
    107
    Nice crack in my p4de!
    13$ fix! Lol
