Results 1 to 2 of 2
    Wake Forest, NC
    406
    Stripped bulkhead - need suggestions for replacement
    Hit a wood chip at high speed and the car lifted up and then did an end-over-end spill sideways about 10 times before coming to an end. After that both wheels had separated from the bulk head, the screws had just been pulled out so the threads are shot. Looking for a more durable replacement. Any suggestions?
    Thanks,
    Jarod
    RC Turnbuckle Jr. Desert JATO's Avatar
    Aug 2007
    Riyadh, Saudi Arabia
    5,661
    if you are reffering to the front upper and lower bulkhead that been damaged, i guess that you should replace them then get an reinforcment plate that will help keep it hold tight during jumps. Check neweramodels under jato parts.
