+ Reply to Thread
Results 1 to 16 of 16
    Sep 2011
    Colorado Springs
    81
    DIY Setup Board System
    Well, over the last couple of days, I made my own setup system to get some more accuracy in setting up caster, camber, etc. I just couldn't see spending $100 - $300 for a hudy setup. The principle of what I made for the Revo was the same mostly, and it'll do what I need for my ride. I don't race and don't really bash hard, I just run the car and enjoy it. When I do run it, I like it to drive strait and handle well. Anyways, here goes.
    I didn't like trying to eyeball all of the adjustments at the wheels. After running the car and having to trim it right 13, I knew there needed to be a better way. It wasn't accurate enough for me eyeball. I knew I needed to do something so I had an idea of using plexi glass. This provided me with some strait edges to get accurate measurements from. Trying to measure at the tires that may or may not be glued exactly right (I mean that one of them may be glued in the rim deeper than another ) bugged me.
    I started out with two pieces of 8" x 10" x 2mm of Plexi glass (lexan glass). These two pieces were cut down to 6" squares. I cut the squares with a utility knife and it worked relatively well. I've used this method before with success, and thought that on 2mm glass it'd work. Basically, I made the measurements, marked the plastic covering on the glass with marker, made the cuts (3-4 cuts) on the lines using a metal strait edge to guide the knife before broke the pieces I didn't need off. Once the squares were made, I made more measurements to find the centers of the 6" squares. Once the centers were found I used a pilot drill bit on my dremel press, and then finished it off with a 6mm bit. This is what I ended up with:
    The arrows on the pieces show the corner (leading edge) of the glass that is factory cut on both sides. This gives me the best possible edge to set the truck on and make measurements from. While the edges where I cut are strait, they are also not as clean as the factory ones.
    Once they were made, I added center lines for additional accuracy.
    Next step was to make the base. For the base I used a piece of thicker glass that was 24" x 18". I left this piece the factory size. I also grabbed my metal strait edge, permanent markers, non permanent markers (which I didn't end up using), and a marker eraser (the white one in the middle).
    First thing I did to the board was remove the plastic film from one side and draw a center line.
    Then I about crapped my pants and realized that I have some serious sucking up to do with the wife. I hit a Christmas ball that my wife and I have had since our first Christmas, 14 years ago, and broke it. Talking about palm face plant!
    And double crap!
    Got the mess cleaned up, sucked up praising the wife as my goddess for 20 minutes, and went back to work.
    Then what I will call axle lines. On the axle lines I made more marks. The first one was at 10cm from center, then at 15cm from center and 1cm each line after that. The long line in the picture is actually the axle line.
    This is what the above looked like after I was done.
    The measurements I used were what I got off of my ride. Axle width of 37" and axle to axle of 32". Remember, the axle width will change with how the pillow balls are set into the arms.
    Some shorter blue lines 1/2 cm between the longer black lines.
    Sep 2011
    Colorado Springs
    81
    And the completed product. I used some paper while drawing the lines for contrast. After I was done, I masked the edges and painted the underside. I also had some rubber feet that I added to the corners.
    Leaving the glass clear wasn't an option because it would have made the lines too hard to see. Especially on my black work bench. Prior to painting the glass, I removed the film from the back side, and cleaned with denatured alcohol.
    Here's pics of the finished product. I am using some military style protractors. They have 360 degrees marked on them and cross lines in the middle so they can be centered well with the board. Eventually I'll get a camber gauge, but that's a few weeks away. I make sure that the squares are centered on the axle line, and make adjustments as I see fit. The 1/2" holes for the pillow ball adjustments aren't as clean as I would have liked, but it works for what I need and allows for camber adjustments. Easier than having to measure, remove the wheel, adjust, replace wheel, etc, etc, etc.
    Hope this helps someone else out. There was a total cost for me of around $24 for the glass. Paint, markers, etc, I had already at the house. I think with the spare pieces I have left from cutting the 6" square, I'll make some mounts for the rear wheels.
    My house! Right down the hill from my chicken coop.
    85
    Really cool! Exactly what I was hoping to do. Nice touch with the clean edge!
    UNknown
    4,216
    with the right tools and equipments anything is possible to do. great job!!!!
    El Centro, Ca
    233
    Nice, I'd say you saved your self some money and had the gratification of building a set up kit yourself.
    Simi Valley, CA
    499
    Very cool setup! To set the toe I always end up using a camber gauge laying on its side with a board behind the wheels as a kind of a straightedge. I like your way a lot better! Can I borrow it? LOL - Nice job!
    Brisbane, Australia
    401
    Nice setup mate, it gives you more self satisfaction when you make it yourself. So was it your ball or hers you smashed?
    I am here: http://maps.google.com/maps?ll=-27.475216,153.018304
    Sep 2011
    Colorado Springs
    81
    Thanx guy's. There's still some tweeking I feel I need to do to it, but it'll get figured out. I posted it here to give some others an idea of a simple solution.
    If I can I like to do things myself, saves money and gives me time to tinker. When the truck is right, I gotta find something to do.
    The ball I broke was ours from our first christmas. It was a gift from a friend of ours that doesn't live close anymore.
    Simi Valley, CA
    499
    Sooo...what day did you say I could borrow it? LOL
    Sep 2011
    Colorado Springs
    81
    When ever you are in the springs.
    Sep 2011
    Cairo, Egypt
    272
    very nice work man..i ve always contemplated creating something similar. not sure if you are aware of this, but there are some ready made setup declass with the all he measurements. you can get for about $20 and it would fit your creation perfectly. try searching for them, hudy is got some i think
    Jun 2009
    Cocoa Florida
    3,456
    Cool idea about the board, I made my mine round instead of square but either way works.
    Your gonna like the RPM monster gauge, it is defiantly worth the $12.
    Setting toe
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    Sep 2011
    Colorado Springs
    81
    @akadi I'll have to check that stuff out.
    @wildman, Nice. I guess in retrospect I could have used a big hole saw that I have to make the disks round.
    Sep 2011
    Cairo, Egypt
    272
    search for "set up board decals"
    Jun 2009
    Cocoa Florida
    3,456
    At the time I didn't even think about the fact that I could make them square, and I had a large hole saw kit laying on the shelf.
    If I didn't have the hole saw kit they definitely would have ended up square!
    I'm thinkin I'm gonna have to make me a board too, yours just looks too good not too!
    LiPo? Naw NITRO!!
    Sep 2011
    Colorado Springs
    81
    Thanx dude.
