Page 1 of 2 12 LastLast
Results 1 to 40 of 69
    May 2009
    Edmonton, Alberta
    3,546
    Joining the Slash 4X4 world. Progress thread.
    Bought a Slash 4X4 Platinum roller today. Hope to see it in the next week or so.
    Loaded up with all the STRC parts. No electronics or body. which brings me to my first questions.
    Motor/ESC - I don't think im going to race this guy, if i get into racing im probably going to race my Xt8-e in the E-truggy class im told is actually gonna start up around here next year.
    Which motor/esc should i look at the stock Velineon or maybe the Castle MMP SC/2400kv. Probably only ever going to see 2 or maybe 3s lipo. Any real pros or cons to either?
    Body - I have seen a couple guys do the backslash conversion. What buggy body do you use? And what wing mount is used or do you just custom fab something up? Dont know that im going to go that route, just curious.
    17mm Hubs - best choice?
    Heres a pic.
    Virginia
    657
    Welcome to slash community. just got my slash 4x4 to go with my 2wd. and if you are only going to run 2 or 3s I would stick to 1/10 electronics.. for bashing the VXL is great cause the waterproof.
    Sorry if hard to read.. a tad late!
    El Sobrante, Ca
    7,068
    Where are you putting the STRC parts? The MMP 3800 might be a good choice for a combo.
    Welcome to the addiction
    May 2009
    Edmonton, Alberta
    3,546
    this is the list he gave me of whats on the truck right now.
    Parts list:
    Traxxas:
    SLASH 4X4 PLATINUM (#6804) (minus body)
    Cover, gear (clear) (6877A)
    STRC:
    STRC CNC Machined Aluminum HD Rear Shock Tower (Blue) for Slash 4x4 (ST6830B)
    STRC CNC Machined Aluminum HD Front Shock Tower (Blue) for Slash 4x4 (ST6839B)
    STRC CNC Machined Aluminum Multi-Piece Steering Bellcrank set (blue) (ST6845B)
    STRC CNC Machined Aluminum HD Motor Mount for Slash 4x4 (blue) (ST6860B)
    STRC CNC Machined Aluminum Electronics Plate for Slash 4x4 (blue) (ST6877B)
    Losi:
    Front/Rear Shock Set (4): 8B/8T (LOSA5417)
    RPM:
    Black Front Bumper & Skid Plate for the Traxxas Slash 4x4 (80022)
    Black Rear Bumper for the Traxxas Slash 4x4 (80122)
    Mud Flap System for the Slash 2wd & 4x4 (81012)
    I have already bought a 2nd chassis tray as i seem to like all my chassis black all of a sudden lol.
    El Sobrante, Ca
    7,068
    Wow, that is an impressive list of parts! That is a nice truck!
    Houston, TX
    627
    +1 on the MMP 3800 that's what i have and its awesome on 2s and insane on 3s
    the 2400 is more for 3s and 4s
    trash that STRC motor mount, you might have trouble with debris getting into those holes that are cut away i had that mount and had to fill them in cause every 10 min i would get debris stuck inbetween the pinion/spur when bashing.
    definitely get a kingheadz
    Boogie Down BRONX
    369
    Quote Originally Posted by Koda Dank View Post
    T
    Yeah you definitely want to get the Kingheadz motor mount with the larger bearing
    As for system combo's i went with the MMP 2400 by caslte all i do is bash i can gear it
    Crazy or gear it conservently and never have to worry about heat issues i hardly run it at
    Full throttle but knowing i have the power there when i want it IS SWEET
    Just think when you where a little kid on a swing and someone was pushing you
    You always wanted them to push you harder so you could go higher.
    same concept with your ride once you get it where you like it you start
    Thinking a want to go faster.. LoL
    It's the addiction to this hobby but mostly its the KiD inside that wants more..
    Good luck KiD....
    BASH!! BASH!! BASH!! & BASH IT AGAIN!! <CAGE RAGE>
    Southeast Michigan
    295
    Nice shocks, and welcome to the money pit
    Those D8 or Losi 8ight shocks?
    SSC SLASH 4X4
    May 2009
    Edmonton, Alberta
    3,546
    I think they are the buggy ones.
    Any other must haves, that aren't on the truck already?
    I am ordering the AKA 17mm kit, and the King Headz motor mount shortly. And a body, and an over tray, and.... it starts haha
    Lake Jackson, TX
    1,203
    good start! I have the aka adapters and I stripped two nuts already. I also have the traxxas ones and those are pretty nice but I have a hard time taking them off. I like them both but need to not over tighten them.
    Anza Sl2sh Bandit EMBEx2 Tekno(Revo D8 D8T MBX6)
    May 2009
    Edmonton, Alberta
    3,546
    which nuts did you strip? the small ones that attach the hub to the truck?
    4
    One thing youll wanna do is to prevent the bearing on the spur from exploding. You ca do that by milling your motor mount to make the hole larger, and the latheing a rod of brass into a brass ring. Then slip the brass ring around the bearing and put them both into your motor mount. If you have problems with your bearing adapter, buy a aluminum one, or make one.
    May 2009
    Edmonton, Alberta
    3,546
    Kingheadz mount has larger bearing and this has center differential installed... not sure if that's the bearing you are referencing or not.
    Houston, TX
    627
    yes that is the bearing being referred to and if you decide to go 3s you might want to pick up a slipper clutch
    May 2009
    Edmonton, Alberta
    3,546
    i think he is sending the slipper assembly as well with the truck.
    Lake Jackson, TX
    1,203
    Quote Originally Posted by Cameron View Post
    yeah those.
    May 2009
    Edmonton, Alberta
    3,546
    i ordered a pack of spares at the same time just in case. saw them and figured eh why not.
    Ontario, Canada
    1,192
    Skip the over tray and get the Outerwears shroud.
    May 2009
    Edmonton, Alberta
    3,546
    i bought the over tray if for nothing else to run it by itself with no Truck body.
    Not for dust and debris protection.
    May 2009
    Edmonton, Alberta
    3,546
    Ok so im trying to do the figuring for my ESC/Motor combo. Castle it is going to be but...
    Mamba Max Race Pro SCT ESC/1410 3800kV Motor 5mm (540 size)
    -or-
    Castle Creations Mamba Max Pro 1/10 Scale Short Course Brushless Combo w/Neu-Castle 1415(2400kV) (550 size)
    Which one will handle better on 2s lipo with maybe the odd 3s run (not likely though as i have to buy enough batteries already and don't need a 3s for anything else)
    May 2009
    Edmonton, Alberta
    3,546
    also, the truck has the center dif installed now but is shipping with the slipper assembly, should i swap that back right away for general bashing?
    Boogie Down BRONX
    369
    Cameron the 2s will work but it would be like your running the nimh battery that came with the truck.
    the 2400 is awesome on 3s geared right and on 4s its crazy sick just need to watch your temps on the
    4s....
    May 2009
    Edmonton, Alberta
    3,546
    I dont need the offroad stuff to do 60-70 mph. I have onroad stuff to do crazy speed with.
    Atlanta
    649
    I agree with you^ Can we see more pics of the d8's on you slash?
    May 2009
    Edmonton, Alberta
    3,546
    Once i get home i have a couple pics from thw seller i can post.
    May 2009
    Edmonton, Alberta
    3,546
    Here is the rest of the provided pics.
    Like i mentioned earlier, there isn't anything necessarily wrong with this chassis, the threaded bars up front are where he mounted his AMB and im pretty sure the 2 small holes in front of that are for access to the steering linkage (could be wrong i never asked) but me being me i like to start fresh(er) so im buying a new chassis and its gonna get a RIT bath and i will be going all black on this one as well.
    May 2009
    Edmonton, Alberta
    3,546
    The stock spur with the slipper and/or the center diff... what pitch are those both? Not indicated on the exploded views.
    Are the M0.8 or 32p ?
    Im still trying to decide of i go with the MMP proSC kit with the 5mm shaft or just use the 3800kv with the 3mm shaft i have here and just buy me a MMP ESC.
    May 2009
    Edmonton, Alberta
    3,546
    It was a good news bad news kinda day. Bad news is both the Oilers and Penguins lost tonight. The good news is, truck showed up today.
    Not much doing as of yet, waiting for the new chassis to show up and for that to take a bath before i do much of anything.
    So far sitting here for this truck are the AKA 17mm adapters and the KingHeadz motor mount. I also have a Jconcepts Truth body out for paint with the JC overtray.
    I may or may not replace the arms, i think the ones on the truck are ok, just a bit dirty and they will get cleaned up at least on tear down when i start transferring parts to the black chassis. Ordered up a couple odds and ends tonight, new center shaft cover and clear gear cover, as these ones are a bit cracked up, although by design it doesn't look like there's much of an option for that (from traxxas anyways, haven't looked much further). And a new drive shaft as well.
    Really good news for the night is that the Jconcepts illuzion buggy body i was sent that was packed wrong for my rc8be will fit with a bit of creativity around the towers should i decide to go with a backslash theme
    May 2009
    Edmonton, Alberta
    3,546
    Ok so it turns out i cant read or the LHS website didn't clarify. But i had bought the "Truth" for the 2WD slash so it didn't fit. Only found that out after cutting it out. Sold that for $20 and picked up a Manta shell.
    It has got a nice mean look to it IMO. And it isn't too busy with extra stuff on the body. I'm thinking black and white. But will have to see where the paint ends up.
    Also received the new chassis and goodies. Once i get around to dying the chassis this rebuild will start coming together.
    May 2009
    Edmonton, Alberta
    3,546
    Still no paint, but the Manta is ready for paint. Got my springs as well. Aren't they purrdy lol.
    Been busy on the weekends and havent had a chance to do the new chassis yet thats still to come.
    El Sobrante, Ca
    7,068
    Get some Mip X-Duty shafts! You have a good looking setup there
    May 2009
    Edmonton, Alberta
    3,546
    Are they really required for 2s? thats all i intend on running. came with the 3s battery bar but i have a 2s bar waiting to go in the new chassis once i get it dyed.
  33. #33
    May 2009
    Edmonton, Alberta
    3,546
    I'm almost ready to sell the truck, just not feeling it and not sure i want/need to sink any more money into it. I would convert it to on road but i already have 3 on road vehicles. i would convert it backslash style but i already have an 1/8 buggy.
  34. #34
    El Sobrante, Ca
    7,068
    Have you ran it yet? I think you need to sit back and enjoy it for a bit. It does sometimes get frustrating building something.
  35. #35
    May 2009
    Edmonton, Alberta
    3,546
    haven't even ran it, just thinking about what i have already spent on it since i bought the roller and what i still have to spend... thinking if there is any time to get out of it and not loose a mountain of money on it now is the time. i have it on the local kijiji,see what happens over the next couple days. if nothing i'll be buying the ESC for it and dying the chassis and assembling on the new black chassis and going to town. Worst case, if i still don't like it at least i would have an ARTR to sell haha
  36. #36
    9
    Don't sell it! Don't sell it!
    Looks like you have the makings of an awesome slash there
    I have 3 of them....stick with it and finish it!
  37. #37
    May 2009
    Edmonton, Alberta
    3,546
    Ok lets start with a question then. sway me towards keeping it lol.
    When i returned to RC after a few year hiatus my first truck coming back was a Slayer on the 2.5 chassis... it handles like trash and found its way into a revo conversion after about 2 months. Loved the revo platform in comparison.
    How does the slash handle in comparison to the Slayer? not as a SC just in general.
  38. #38
    El Sobrante, Ca
    7,068
    That is the beauty of the Slash! You can make it handle any way you want it to. I have one that is looser on the suspension and one that is glued to the road. It's easy to tune it to your liking
  39. #39
    May 2009
    Edmonton, Alberta
    3,546
    good to hear, this one has the center diff installed. if i am just bashing should i be running the slipper?
    MMP SC pro 2400kv on 3s 50c 5000mah. What gearing should i be looking at.
  40. #40
    El Sobrante, Ca
    7,068
    I would recommend the slipper. I would gear it at least 20/50. If you want more speed go up! Mine is geared 22/50 on 4s
