    Nov 2011
    46
    Question Quick Question: Whats Cogging?
    Just as the title says! Whats cogging? I was told my car wasnt working because my car is cogging or cogged!
    Feb 2002
    4,613
    isn't working?
    cogging is a slight hesitation on brushless power systems that happens upon initial acceleration from a stop. the batteries, or speed controller aren't able to immediately deliver all the power the motor wants
    Nov 2011
    277
    http://www.youtube.com/watch?v=GLmCek1RNF0
    Interesting view point, I thought it was the effect of running a very low throttle pull at stopped speeds.
    Rotterdam, Netherlands
    7,244
    Cogging is also influenced by the wave form which the ESC feeds. It only happens at low speeds.
    Nobody is born with experience.
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,127
    With a sensored system the sensor tells the ESC where the rotor is positioned so the ESC knows which wire to fire current at first at all times. With a sensor-less system such as the VXL the ESC has no idea where the rotor is from idle and so it is in effect blind and does not know which wire to fire voltage on first to smoothly get the rotor turning. This can cause a stutter or cogging. The cogging is magnified with weak batteries or bad connections. Once the ESC gets the rotor spinning they sync up and if all is right the system should run smoothly.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
