Results 1 to 14 of 14
Thread: lock diff
    349
    lock diff
    How can I lock the rear diff on the slash 4x4?.Thanks.
    Lilydale, Victoria, Australia
    2,845
    Hot Racing sell a part that will do it (Diff Lock Posi Spool SSLF125)
    Cheers
    Slash Platinum
    wales uk britain
    169
    two ways i have found
    1st-open the diff so you have the planet gears out degrease them then put them back in and fill up the diff with hot glue (i wouldnt do it this was as its permanent and if you dont like it you will have to replace the diff)
    2nd-open the diff again and get rid of most of oil then put nitro fuel line in there pushing it in to it to lock the planet gears (i did this on a drift car and it worked well but there was not half as much power in the drift car as a slash has got)
    i would up grade the drive shaft because you will be puting alot of stress on the stock ones
    349
    Ok thanks have the MIP X dutys on the way so will they be strong enough?.And are the planet gears the little gears inside the differential?.Thanks.
    wales uk britain
    169
    Quote Originally Posted by S.R.C.H View Post
    yes it is the little gears inside the diff amd as long as your not always on a high traction surface flat out then the shafts will be fine
    349
    Ok thanks for all the help.
    wales uk britain
    169
    let us know how it goes and how well it drifts
    349
    Ok thanks the update will be after Christmas.
    Houston, TX
    627
    I've done it JB welded the rear diff and it pushes way to hard real hard to control
    With the JB weld if you dont like it you will have to rebuild a whole new diff to replace it
    There is also a spool you can get on ebay for $20-$25
    If you are looking to drift I would just fit PVC pipe over your tires
    349
    Ya I wasnt gonna do anything permanent was just going to try it out.Thanks for all the help.
    Houston, TX
    627
    you could probably get away with using silly putty or something in that nature
    Nov 2011
    Bozeman, MT
    93
    Quote Originally Posted by Koda Dank View Post
    +1. This is an old school diff locking trick that people seem to have forgotten about. Very cheap, you can get it locally, it'se removable, and unlike glue/JB Weld/etc it doesn't throw your diff out of balance.
    wales uk britain
    169
    didnt even think of putty dont think my kids would be happy though
    e-revo
    slash 4x4
    summit
    rustler vxl
    349
    Ya thanks will do the silly putty lock as soon as possible.Thanks.
