+ Reply to Thread
Results 1 to 12 of 12
    Rotterdam, Netherlands
    6,384
    Sway bars and shock protectors
    I am looking for a way to mount sway bars and keep the shock/arm protectors. It seems I have to get rid of the protectors to be able to mount the sway bars. Anyone with experience with mounting them both?
    Nobody is born with experience.
    RC Turnbuckle Jr. RC-Fan's Avatar
    Jun 2010
    Miami, Fl
    6,649
    I just that mod on a LHS, they replace the screw on the sway for a longer one that attach both parts to the arm with the same screw.
    FLM - EMAXX
    6,384
    I took the hollow balls out of rods I had laying around and put those in place for the pillow balls. They have the same length as the plastic busses. Problem solved
    Northern Illinois
    56
    Or you could just move the protector towards the wheels and move the screw with the plastic boss next to it, that's what I just did.
    6,384
    Quote Originally Posted by Tmaxxos21 View Post
    Not sure if I understand what you mean. I assume you have the shocks in the hole closest to the wheels then. Right?
    Northern Illinois
    56
    I have the sway bar link in the closest hole on the arm, the shock in the stock position mine came with, and the other screw with the plastic spacer one hole away from the shock towards the wheel, this means you have to move the guard in that direction. I do like your idea better though since I do have some old shocks laying around with the ball inserts...
    6,384
    Got it. I just wanted the guards in the same position.
    Northern Illinois
    56
    I agree with you there, it looks "normal" to have them there. I might swap out the ball screw and put a long one in there like you did, one less part to worry about
    Corpus Christi, TX
    466
    Thanks for this. Was just putting sway bars on my Stampede and was confounded.
    6,384
    Quote Originally Posted by johnh2005 View Post
    Cool. I was like when I saw this thread active again. Good thing you used the search function instead of starting a new thread.
    Corpus Christi, TX
    466
    Yeah, I usually try to. Though sometimes my questions are very specific. I try to encourage other people asking questions to use the search function. Just would not be right if I did not do it my self (at least sometimes). A LOT of useful information buried here...
    6,384
    Agreed. There is tons of information. I remember doing quite some searching before I started this thread.
    Nice to leave a message that the info was useful in this case
