Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    26
    Which knuckles should I upgrade to? I like RPM but there still only plastic should I go Aluminum? any good brands?
  2. #42
    Alma, Michigan
    12,291
    RPM knuckles do not work for these guys.
    Go alloy!
    GPM is a forum favorite
    HR is good, IF you get a good set.
    (The last HR set was all good... I think EatToMuchRice bought them)
    (or something like that lol)
    The threads on HR are sometimes goofy.
  3. #43
    26
    OK now I've run about 6 packs through it and still haven't broken anything yet. I changed the pinion to the 23T and am running 2s 2200mAh batteries on GRASS, would this put to much strain on the motor? should I change the pinion back to the stock one?
    Also does anyone know how fast you can charge ******* batteries?
  4. #44
    Alma, Michigan
    12,291
    The pinon that came installed would be harder on the system than the "speed" pinion.
    The name is totally misleading...
    The speed pinon is actually SLOWER when fed the same voltage.
    I run 2S 2200mah 20C's in parallel in all types of terrain without issues.
    Be sure to keep an eye on temps and you will be fine!!
  5. #45
    Australia
    29
    Hi try hobby king online, I use it heaps as I live in Perth, things take for ever to get here, it's taking me ages to do my big
    Block
