I seem to have problem with my Steering Bellcrank Assembly seem to got loose
if car is on the and I try to turn wheels the wheel on the ground doesnt turn,
Any good advice on that!
Should I change it, if so aluminium or stock?
Thanks in advance
Thanks in advance
Check the bearings in the bellcrank and make sure that its not full of dirt. also check your steering servo
Did not know there was bearing in there! that one part I did not dismantle so far, just looked the exploded view and see there is 4 bearing....I know what I will do tonight, that must be the problem, car is 5 months old and never open that part
Thanks for the advice I let you know if it was the problem...
Amazing difference when I replaced those 4 bearings.
I went to the STRC setup! It works WAY better than the standard steering.
Slash 4x4 SCT 2400
Slash Ultimate MMP 2400
Do Traxxas make a factory upgraded alloy bell crank?
Slash 4x4
Spartan
Stampede
Rustler x 3
I clean all 4 bearing last night as Jay told me to do, havent try it yet on run, but I can notice a difference right away
It move way more freelly, so I can wait to go alloy
Thanks Jay janak!
