Results 1 to 3 of 3
    212
    My mini summit is sidetracking?
    I thought that I turned the steering trim knob and that's why my summit was sidetracking. Well I noticed the right rear tire is pointed in slightly so the truck won't make a straight path. I replaced a drive shaft on that wheel and adjusted the shocks a bit and that's when I noticed it sidetracking. Is there some way to adjust it back?
    Alma, MI
    12,281
    Pillow balls.
    There is supposed to be some toe in back there... keep that in mind!
    21
    The best way to keep both tires in balance is to do the following:
    1) Take both rear tires off
    2) Take the two pillow balls out of the right and the two pillow balls out of the left
    3) Now screw all 4 pillow balls back in just to the point where you can no longer see the threads. No more, no less. This will make all 4 the same so be precise.
    4) Now at this point screw both the TOP and BOTTOM balls in 4 1/2 turns. This should set them back to stock settings. If they bottom out before the 4 1/2 turns just do 3 1/2 turns. This will ensure that both sides are identical. If you do something to one side the other side needs to be done the exact same.
