Results 1 to 18 of 18
Thread: Jato 3.3 BUILD
    Red Deer, Alberta
    242
    Jato 3.3 BUILD
    So I have been looking at getting a Jato 3.3 for a while now. I have decided to buy it piece by piece, most off EBAY. And start putting it together over the winter.
    What upgrades do you guys suggest be done? What upgrades did you guys do?
    REVO 3.3
    HPI SAVAGE X 4.6 Big Block
    AXIAL AX10
    Sep 2008
    NYC
    1,020
    Its going to cost you ALOT to build it piece by piece. Better off buying a roller or a cheap RTR and just upgrading as you go.
    1/16 Revo VXL - - - Spartan
    Red Deer, Alberta
    242
    I don't know. It gives me something to do over the winter when its -30 - -40 degC.
    LOL LOL
    REVO 3.3
    AXIAL AX10
    Red Deer, Alberta
    242
    So I have bought almost everything off of EBAY, just missing a couple parts.
    Major one is the engine and that's about it.
    What upgrades go you guys recomend, and what ones did you find you needed to do?
    I got the front and rear swaybars, I don't know if the Jato 3.3 comes with those stock or not.
    Your comments are appreciated!!!!
    REVO 3.3
    AXIAL AX10
    Red Deer, Alberta
    242
    O.... And sofar I am only in to it foe 183.00!!!
    REVO 3.3
    AXIAL AX10
    Sep 2008
    NYC
    1,020
    Quote Originally Posted by justinaskin View Post
    What did you get for $183?
    Also, sway bars on the Jato are useless.
    197
    are you actually looking to put all traxxas upgrade parts on your jato? in that case, you might end up paying almost $500 on your r/c
    119
    Quote Originally Posted by RobF353 View Post
    sway bars work sweet as long as you run onroad. i have to run them for onroad racing. with out the body roll is too much and i keep flipping even though my jato site about 3/4 of an inch off the ground.
    Red Deer, Alberta
    242
    Sooo.... Im getting toward the end of the build. I am having a problem with the steering servo. Is there a trick to installing the linkage on to the servo horn? I don't see bow it is to be done.
    Once the servo in in there is just not enough room to put it on let alone make sure it is centered.
    Any help is greatly appreciated!!!!!
    1.0 - Spider / Ball Python
    1.0 - Pastel, Het Orange Ghost / Ball Python
    0.1 - Pastel, Het Orange Ghost / Ball Python
    0.1 - German Shepherd (Kahlua)
    REVO 3.3
    AXIAL AX10
    15
    Easiest way is to remove the front end by removing the 4 or 6 screws(cant remember which) on the bottom of the chassis. The front then slides out making it easier to center your steering.
    Red Deer, Alberta
    242
    Ok I am a little confused here. The linkage that goes onto the servo horn for the steering has a arrow on it. Which way dose it point. Up, down, right or left?
    1.0 - Spider
    0.1 - Mojave
    0.1 - Pinstripe
    1.1.0 Dendrobates Tinctorius “Azureus”
    1.1.0 Dendrobates Auratus "El Cope"
    REVO 3.3
    AXIAL AX10
    527
    From memory, it points up.
    Here's how I installed mine:
    1. Make sure the servo is set in it's centre position.
    2. Took the front end off.
    3. Put the servo horn on
    4. Held the front end back onto the chassis, while using the remote to see if it works.
    5. If it wasn't set up right, I would just move the horn.
    Red Deer, Alberta
    242
    Quote Originally Posted by Mind_Reader7 View Post
    Thanks!!!
    Would you be able to help with another problem.
    How do I run all the wires to the receiver? I have never seen one up close all put together.
    1.0 - Spider
    0.1 - Mojave
    0.1 - Pinstripe
    REVO 3.3
    AXIAL AX10
    527
    There's little routing holes in the top chassis. They allow the plugs to fit through into the receiver box.
    RC Turnbuckle Jr. RC-Fan's Avatar
    Jun 2010
    Miami, Fl
    6,491
    Black connector goes into the receiver, one the reds is to power the rx, servos, and the other is to charge the receiver pack in case you are running a rechargeable one, to difference between the two reds, just plug the batt pack on any, and if it power the rx, that's the one. It is easier if you remove the top chassis, and run all the wires.
    FLM - EMAXX
    Red Deer, Alberta
    242
    Where do you actually run the wires. You wouldn't happen to have a picture of a completed Jato so I can see do you?
    1.0 - Spider
    0.1 - Mojave
    0.1 - Pinstripe
    REVO 3.3
    AXIAL AX10
    4
    get a os21tm(1.8hp) engine with motor saver airfilter, plus steel trans. 5cell battery for center mount. get traxxas CVD's too. those are the upgrade i would get if i had the money .
    527
    Quote Originally Posted by OP_TRX3.3 View Post
    If funds were unlimited, I could suggest an entire page of things he should do.
