Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 41 to 80 of 89
  1. #41
    u.k.
    1,428
    ******* and tenergy are different companies, If it was tunrnigy then i don't know what their chargers are like, the lipos I find ok, If they are tenergy then i stand by my previous post.
    Motorcycle/Quad,Think sand vehicle, piggy backs
  2. #42
    May 2010
    281
    lol trax i was just looking at a tenergy charger.
  3. #43
    1,346
    Oops my bad!
    But still, I'm happy with the ******* LiPo's
  4. #44
    u.k.
    1,428
    MnM me too, lol
    I forgot what mine was White TB6 or something,I have a pic where it charged my 6cell nimh to nearly 11V the other to about 10V. Worked great first charge,second charge, didn't quite manage a third charge and ruined my nimhs. Thats what made me buy LiPo.
    They do look good. Maybe mine was just a dud.
    I Bought a more expensive 3x the price, same spec charger never let me down once.In over 12months.
  5. #45
    May 2010
    281
    oh ok yeah i just ordered some parts all i need now is batts to get this running.
  6. #46
    1,346
    I'm using the Thunder AC6 charger and again, happy with it. It's just a single battery charger but will charge just about every type of battery under the sun.
    This is my second one though. The 1st one I had to send back because one of the buttons stopped working. The vendor refunded my money and I just ordered another one. No problem with the replacement.
  7. #47
    May 2010
    281
    i might grab a onyx 230
  8. #48
    May 2010
    281
    Anyone know where they sell traxxas funny car wheels the rear i got a weird idea
  9. #49
    May 2010
    281
    What do you think of the thunderpower a6 charger guys
  10. #50
    Sep 2010
    Chicago, IL
    1,750
    Do you mean Thunder AC6 off amazon or hobbypartz or Thunder Power A6?
    1. ThunderPower is a seperate company that makes top quality racing LIPOs and chargers
    2. The Thunder AC6 is made by a compleatly different company that is a division of HEli-X or something I think
    3. THunderPOwer dosn't make a A6 charger
    "American Muscle beats import any day of the week"
  11. #51
    Sep 2010
    Chicago, IL
    1,750
    Has anyone ever got the Thunder AC6 computer program to work?
  12. #52
    May 2010
    281
    oh ok yea its a thunder Ac6. maxx what charger do you use?
  13. #53
    Sep 2010
    Chicago, IL
    1,750
    That and a older onyx for my NIMH.
  14. #54
    May 2010
    281
    how do you like it
  15. #55
    May 2010
    281
    Got an Update I got the wires extended on my esc... Conclusion my soldering Sucks :P
  16. #56
    May 2010
    281
    got the esc and motor wired. All thats left to do is get the gear off the motor which is impossible for me HAHA and wait for my batts.
  17. #57
    u.k.
    1,428
    The stock dewalt gear, it's glued and shrunk on, You need to cut down the length between the teeth don't go down to the shaft.
    Flip it 180 degrees and cut again, this time you can go down to the shaft. Use a decent size flat blade screwdriver and twist the gear off, the gear should just snap in half.
    Then the side where there is a mark from where you cut you need to grind a flat area for the new pinions grub screw to fix too.
  18. #58
    May 2010
    281
    lol i tried earlier and completely failed hahah
  19. #59
    u.k.
    1,428
    as long as you don't try and force the pinion off,
    Just keep cutting inline between the teeth and a large flat blade screwdriver to twist it apart.
    Your cutting disc maybe to large you need to go the full length of the pinion, I done two cuts length ways and two width, so it looks like it's quartered came off very easy.
    You could try 4 length ways maybe easier.
    but do it where you can pick up the pieces the glue is strong and will fly off accross the room.
    on here you can just see where i cut into the shaft slightly.
    but then you just grind that down to make a flat spot.
  20. #60
    May 2010
    281
    alright ill give it another go
  21. #61
    May 2010
    281
    yo trax how did you break in your motor underwater??
  22. #62
    u.k.
    1,428
    sort of,
    Boiled some water, Let it cool poured it onto the brushes in the motor and turned by hand for a few minutes, then dipped the rear in the water up to soak the comm and brushes then ran on training mode for 5minutes,I was meant to use a full pack but got bored and put it back in normal mode. That was it.
    The brushes are pretty well shaped new so the break in doesn't take much, if it went wrong just buy new brushes for $3 and start again a different way.
    The water really acts as a non chemical lubricant.
  23. #63
    May 2010
    281
    yea ill prob jus do a water break in then blow it out with the air compressor and lube the bearings
    Oh yea i finally got the gear of the motor
  24. #64
    Sep 2010
    Chicago, IL
    1,750
    I just run it with one 7.2 straight to the motor to break it in. Water break in shortens brush life even though it improves performance. But what the heck, its only $3
  25. #65
    May 2010
    281
    yeah lol im gonna buy some more brushes just have a few sets stored. How long do you leave it in until the battery dies.
  26. #66
    Sep 2010
    Chicago, IL
    1,750
    I dont use water, and i just run it for like 1 min. THen I install it with out a pinion and work the throttle for like 10, at first just slow then more and more until im doing it wide open in both directions.
  27. #67
    u.k.
    1,428
    it doesn't take much at all to break in, remember these are drill motors already pre cut brushes not normal RC motors.
    Well done to getting the pinion off.
  28. #68
    May 2010
    281
    so about a min in some water at half throttle??
  29. #69
    u.k.
    1,428
    training mode gives you the half power after a few mins put in sport/race mode don't strain it over rough land,check temps. If alls good go wild.
  30. #70
    May 2010
    281
    alright thanks trax
  31. #71
    May 2010
    281
    so trax are you saying after i do the water break in do a little breaking in when i run my truck.
  32. #72
    Sep 2010
    Chicago, IL
    1,750
    Maybe also stay away from high C rate lipo too for the first run or two. I have a hard time telling between tranning mode and regular when running lipo, only at full throttle do I notice its slower. Could be my lipo is 65C, 135C burst, or just that im plain out stupid.
    those who know me well would say the latter.
  33. #73
    May 2010
    281
    WOW what lipo do you got maxx and im running nimh for now.
  34. #74
    May 2010
    281
    anymore break in methods?? and a minute or two under water maxx and trax?
  35. #75
    u.k.
    1,428
    The easiest is just wet the brushes and comm turn by hand about a minute, Then run in truck training mode try not to use the brakes for about a pack ideally. I lasted 5min then put it in sport mode.
    hHd mine running for over 1year and still good.
    You should notice when you put it in sport mode every time you take the maxx out for a run, it should get better and better. But remember check temps. Use a safe gear at first. I'm upto running a 28t now with very cool temps.
    I've never seen someone burnout new brushes including from the trade who just swap over and use as normal straight off. These brushes fit in a range of tools not just the drills.
  36. #76
    Sep 2010
    Chicago, IL
    1,750
    I was running a Thunder Power 4s 65C 5300mah G6 pro race pack. Its currently in at TP getting a new case I hope.
  37. #77
    May 2010
    281
    yea im eventually gonna get some lipos
  38. #78
    May 2010
    281
    Took a break from my project but now im back. I had the truck running for a few mins then the power stoping going to the wheels. When I checked i could spin the wheels but the output shaft that the spur assembly is on wouldnt spin with it and vice versa. SO i took off the transmission and opened up I didn't see any bad gears put it back together it spinned how it should but at one point it binds. I can spin it back and fourth maybe 3/4's of a turn the it locks; if I'm spinning it back or forth.
  39. #79
    u.k.
    1,428
    Check the wheel hex's the corners may of stripped off or the wheels has rounded.
  40. #80
    Sep 2010
    Chicago, IL
    1,750
    Are you referring to just the tranny or the entire truck? U dont have 2 speed, so I can imagine what would cause the tranny to lock like that.
    If ur talking about the truck, start going down the drive line and moving everything to see what is good and what is stuck.
