+ Reply to Thread
    Dover NH
    1,354
    Why can't I get my exc to let me use a different tx?
    I'm up camping and I left one of the tx at home, the brushless slash has a vel 3s esc. I'm trying to use a different slash tx with it. I can't get it to bind, I got the book out and for the life of me it won't bind.
    Then I went to the exc manual on here and made sure I was doing it right, NO JOY, any ideas, it's was totally fine with the other tx yesterday.
    Thanks from Lake Placid.
    Al
    15 IS Enough, Time to thin down the fleet some.
    Springfield, MO
    3,686
    Does the steering work?
    If not, you're not bound.
    If so, you're not calibrated....
    Which is it? ESC flashing green fast?
    Dover NH
    1,354
    I'm trying to bind it, the directions say turn on tx, push and hold exc till it turns red, then on the first red blink full the trigger full forward, then you should get 2 red blinks and you push full reverse, I'm not getting the blinks, it goes right to the mode blinks, you know the 3 different run modes, what about a complete reset? how do I start fresh? I'm trying to use a revo tx is that an issue do you think?
    Quote Originally Posted by ducati777 View Post
    Mar 2009
    Portage, IN
    667
    From what I have been able to find is that the (newer) black 2.4ghz transmitter is not compatible with the reciever for the (older or original) grey 2.4ghz transmitter. I am not sure what you have but I know the new vxl slash uses the black controller.
    4908x2
    MERV
    Slash4
    Slash2
    Creeper
    miniSlash
    Mar 2009
    Portage, IN
    667
    If you do get it bound and the steering works but the throttle does not and the esc is flashing green yoiu will have to adjust the throttle trim. I can't remember if the multifunction knob on the 2.4ghz radio is set to throttle trim as a default or not also different models use different modes in the transmitter aswell. The programming guide should tell you wich models use which modes and how to program them. I hope this helps.
    4908x2
    MERV
    Slash4
    Slash2
    Creeper
    miniSlash
    Springfield, MO
    3,686
    Quote Originally Posted by Al Morancy View Post
    Sounds like you haven't bound the tx to the rx... you're missing step 1 here.
    You first need to get the radio to talk to the receiver, once you've got that, you can calibrate the ESC. What you have described is the calibration of the ESC... but if you haven't binded (bound?) the radio to the receiver, you won't be able to complete that step.
    Look up the manual and follow the directions for binding the radio to a new receiver.
    Dover NH
    1,354
    Thanks for the try you guys, I'm trying to bind and it's not binding, lol I have the same tx at home that is bound fine, just left with out it. Got 7 trucks up here, 3 slashes, just figured I could take a different slash tx and rebind it to the brushless one, and it's giving me a hard time binding. Do I need to do a master clear or something? before rebinding, I have the manual and I'm going over and over step by step, I'll look up clear all settings and try again., Thanks guys
    Mar 2009
    Portage, IN
    667
    I found this here not sure if you have this info yet or not. Justtrying to cover all the bases.
    This is for the Tx and Rx that are equipped with Traxxas Link
    http://traxxas.com/support/How-do-I-...itter-receiver
    http://traxxas.com/pdfs/2217_2228_22...24_Binding.pdf
    There is also a forum for transmitters in here as well it is down towards the bottom of the page. I never knew that it was there till today.
    4908x2
    MERV
    Slash4
    Slash2
    Creeper
    miniSlash
