Results 1 to 18 of 18
    70
    Buyn some tires...hex sizes questions.
    Putting some aka racing I-beam truggy tires on the revo....
    http://www.rcplanet.com/AKA_Racing_T...ka14101hpw.htm
    Question is do they just use regular hex nuts like stock black ones(14mm) or the hex nut adapters withthe larger center diameter.
    I know there 17mm just need to know what kind to use.
    thanks
    Ed
    Mesa, AZ
    2,682
    The spec's for the tires say:
    Hex Size: 17mm
    Hows that nitro taste on your electric?
    May 2009
    Edmonton, Alberta
    3,604
    AKA's use the larger diameter hex's if im understanding you question properly. Like the Blue Tmaxx/Revo ones or equivalent.
    70
    http://www.rcplanet.com/ProductDetai...86107&CartID=3
    Ima go with these wheels for the offset .
    And yes the revo I got has the same hex as shown above....do these wheels use the same latger diameter or the standard size with just 17mm hex
    May 2009
    Edmonton, Alberta
    3,604
    those will fit the blue hubs shown above.
    1,255
    Yes those wheels are 17mm, if you have the Revo with 17mm hubs they will fit without any mods.
    There are no stupid questions, just stupid people.
    70
    Awsome thank you.
    Last question will those aka tires fit the ofna wheels
    May 2009
    Edmonton, Alberta
    3,604
    those AKA are premount. im not sure what size AKA uses and what bead they use.
    1,255
    The OFNA wheels are LPR and the AKA tires/wheels do not say the inner size of the tire, you have to be careful with that too, you will have to stretch the tires to fit on the wheels.
    70
    Is the 1/2 offset really worth the trouble of finding wheels that fit?
    1,255
    Is not the offset, is the size of the wheel and the bead what makes the fitting problem.
    1,255
    I don’t know why some manufactures don’t print the tires and wheels sizes in their products. When you go to Proline or Traxxas products you will always find the inner, outer and width sizes of the tires with bead explanations.
    70
    I did some searching.....the aka I-beams are lpr so the ofna lpr will fit
    1,255
    Then try to find the AKA tires without the wheels and glue them on the Ofna wheels and will have the 1/2 offset setup with the tires you like (AKAs)
    70
    Thanks for all the help guys....gottem order'd
    May 2009
    Edmonton, Alberta
    3,604
    Made sure to order 2 lefts and 2 rights?
    i kid. i kid. i ran some of those I-beams they are a pretty slick tire. They burnt up FAST on the asphalt though, recommend keeping them dirty. that was an $80 lesson i wont soon forget.
    1,255
    Quote Originally Posted by Cameron View Post
    Lol..that was good!!!
    70
    I figured they would....i hade some pro-line holeshots and after 3 tanks small gravel they were shot.
