Results 1 to 33 of 33
    Jul 2011
    153
    Question Merv 1/16 2080 Servo replacement.
    Need to find either a replacement servo, or steel gears parts number, had broken gears replaced them, and LITERALLY 20 minutes into a run the gear teeth started to chip again.
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,301
    I dont believe there are any metal gear replacements for the stock servo.
    Common upgrade is a Hitec HS85MG servo, the MG stands for metal gears
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Jul 2011
    153
    And it fits perfectly in the alot? No trimming? How about programming? Just plug and play?
    12,291
    I use the ******* 390.
    98% direct drop in...
    A little trimming on the servo mounting tabs and a servo reversing procedure on the Tx and you are all set.
    All hardware is 100% compatible.
    Here is a link to a servo comparison for all the servo's that I know of that fit this chassis.
    Jul 2011
    153
    Any idea which if any of those are waterproof?
    Jun 2010
    Miami, Fl
    6,731
    none of those are waterproof but nothing that plastic dip can't fix. I have a hitec 82mg (waterproofed), also my sidewinder is too, and the metal gears from the hitec fit the traxxas 2080.
    Jul 2011
    153
    Oh well that's convenient, how exactly would I do a "plastic dip" and which is better? Leaving the gears in the hitec or putting them in the 2080?
    Aug 2007
    So Cal
    21,301
    Quote Originally Posted by RevoRoughin View Post
    Search YouTube or Google for "waterproofing servo" or something similar you will get many hits.
    I dont believe you can put the gears from the Hitec into the stock servo case.
    BlindMan Racing
    SPC Lipo Power
    Jul 2011
    153
    WhIch would be better, the analog or the digital hitec upgrade?
    Aug 2007
    So Cal
    21,301
    Digital is considered a better servo but usually more costly. Just depends what your priorities are. I am using the analog servo and am satisfied with it's performance.
    BlindMan Racing
    SPC Lipo Power
    Jul 2011
    153
    Ooking at then it's a 5$ difference foe digital, probs pick it up next paycheck since obv traxxas one is junk.
    Jul 2011
    153
    Wi the digital version fit from that list?
    Aug 2007
    So Cal
    21,301
    The stock servo is what it is but calling "junk" is a little harsh and very close to crossing the line toward Traxxas bashing. Traxxas does not mind you expressing your thoughts as long as you do it in a respectful manner.
    BlindMan Racing
    SPC Lipo Power
    12,291
    I took it as he was talking about his current broken Traxxas servo.
    Jul 2011
    153
    Your correct in that assumption , wouldn't own a traxxas if I thought it was junk.
    Jul 2011
    153
    I've read that the cable is extremely short, does it reach the box or did you have to mod? An how much trimming was required, it's cheaper than the hitec and has great reviews, any other info you can provide would be great, thanks again.
    Jul 2011
    153
    Decided to go with the ******* 390, for the money it looks to be the best in speed etc, hopefully I can figure out how to "reverse or flip" It so everything goes in the right direction
    Outer Space
    65
    does the ******* 390 servo requires reverse steering?
    Jun 2011
    208
    Yea it requires reverse steering.It's very easy to reverse steering. Just look in the manual or go to support on Traxxas website and it tells you manually how to do it.
    are all the stock parts 100% compatible.
    South Dakota
    351
    im happy with my hitec HS85MG. it does seem to not quite center but a little turn fixes that. it drops right in, the wire is in the way so u have to take the top plate off but thats easy.
    9,244
    Let us know if you can find a 390 been on backorder for a while now
    326
    YEa, i also have heard that the cable on the ******* 390 is pretty short, do you have to modify the receiver box to let the cable reach or can you wire the cable like the stock servo?
    9,244
    look at cobra's car his cable looks pretty long
    Rotterdam Hoogvliet NL
    886
    modify a longer cable is not that hard as long as you can solder
    Xtreme has no limiits
    56
    I just installed the ******* 390, the cable is plenty long enough.
    326
    mindy, where did you buy your ******* 390?
    9,244
    that would be a score on ebay!
    9,244
    and i just scored on cobra's 390 for a spare!
    56
    Picked it up on ebay as soon as it went up for sale!
    San Diego, CA
    85
    I see that there are a few different versions of the 390, has any one figure them out.
    Has there been any other servos to add to the list that Jimmie Neutron's put together.
    Summit; ERBE; E-Slayer; MERVs
    Wraith; AX10; RX10
    San Diego, CA
    85
    So, I figure out the differences between all the different listings of the 390. There is actually only two different models, both have the same speed and torque but:
    green 390 has a 4.8v-6.0v operating voltage.
    blue 390s has a 6.0v-7.2v operating voltage.
    all the other listings of both blue and green are based on which warehouse (country) has them.
    Wraith; AX10; RX10
    My home, Squirrelville, Wild West
    790
    I like the HiTec HS85MG. Not waterproof, but look here for help:
