Tire Help!!
Did a little bashing today after putting the GTR Shocks on my merv and "accidently" got it into some water. So now I've spent over an hour trying to get water out of the tires to keep it from wobbling to bad. But I cant get enough out. What can I do?
cut a little hole on the outside of the tire. match it up with the hole on the inside. just a little pinhole works. then spin ur tires and the water should come out
i would drill a hole not cut.might slip and make it too big
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
