Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 364
Thread: SumRevo
  1. #121
    kansas
    7,835
    Proline slipstream
    tinted the side & rear windows...
    took me three hrs to tape it off......
  2. #122
    kansas
    7,835
    13,549
  3. #123
    Sep 2009
    133
    Good looking Truck....For show only?
    Get rid of the Wing & Tighten slipper all the way
  4. #124
    kansas
    7,835
    Thanks..
    Just the body & tires, rest of the truck has had it's share of broken parts.
    The sun makes it look kind of two tone yellow
  5. #125
    Ft Sask,Alberta
    30
    Wow what a great build,I realy like the paint in the last few shots.Is that some kind of keeper system for holding on to the body clips,if so I sure could use something like that.I lost a couple of clips in the grass,I couldent find them but im sure the mower will.I was nervous about changing out my spur gear the other day,then I looked at your build,man ive got a long long ways to go in the learning curve.I guess thats what these forums are for,an endless supply of good quality info.Enjoy the ride it looks like it was a fun project.
    ERBE , 1/10 Summit.
  6. #126
    Nov 2011
    Western Kentucky
    792
    Looks good next body you paint try using Parma Liquid Mask it works good no fooling with tape required.
    ERBE,Losi 8ight,Slash 4X4
  7. #127
    kansas
    7,835
    some old Fly fishing string, tied to the body clips....
    the wind was blowing, like usual.. blowing the strings up...
    I will get a better pic inside tonight....
    had read about the liquid mask, just using painters tape, & had the KTM screen printed, on Lamenting paper.
    it did keep me out of trouble for a few hrs...
  8. #128
    Nov 2011
    Western Kentucky
    792
    Are you still using stock servos
  9. #129
    kansas
    7,835
    Quote Originally Posted by Brewers74 View Post
    yep..
    they are holding up quite well, I have them adjusted up & no humming.
    I ended up putting the Hitech on my Summit with the 10 amp BEC..
  10. #130
    kansas
    7,835
    some better pics
  11. #131
    kansas
    7,835
    I went & bought some 24mm hubs a few weeks ago. They are HPI 102530 Savage wheel hubs to mount Baja 1/5 tires.
    I also bought a Losi 5ive T, these are the tires off the 5ive T. Losi made the rims hubs about .100 wider. So the HPI hubs are not wide enough to fully screw the hub nut on.
    I'm going to buy some ProLine HPI 5B Rear Bow Tie Tires on Black Desperado Rims p/n PRO115113.
    Becasue I already have the stub shaft spacers all I had to do is put the hubs on..Not to worried about wheel wobble, I don't have any prob's with the 17mm hubs...now.....I prob will not run these very often, one they are huge, Seven inches, a bit heavy, & I prefer my Badlands... Might have to put them on my Summit.....a taller tire might be nice.
    ===as you can see the nut doesn't screw on very far..
    13,940
  12. #132
    kansas
    7,835
    a few weights
    Geode rim 76 grams
    Talon & foam 207 grams
    Sidewall protector.. beadlock style 9 grams
    tire, rim, taped, beadlock...total weight 327 grams
    width 3.225
    OD 5.990
    Badland tire, Geode rim, taped 270 grams
    width 2.750
    OD 5.950
    Org. Trencher on Tech 5 rim 375 grams
    width 3.370
    OD 6.860
    HPI
    Blast Spoke rim, Phaltline tire, taped 290 grams
    width 2.750
    OD 5.530
  13. #133
    kansas
    7,835
    I have the CVD's on the Summit going to try them on the Revo..
    Long shafts in front & short in the rear..
    Top to bottom..
    Revo CV drive shaft
    Summit CVD shaft long
    Summit CVD shaft short
    14,116
  14. #134
    Jun 2009
    W Monroe, Louisiana
    1,995
    Did u get any weights of the 5t tires? They look REALLY heavy.
  15. #135
    Australia
    3,255
    Very nice build...I like it
    Rock n Rolla !
  16. #136
    kansas
    7,835
    ProLine
    Bow-Tie Tire
    Width 3.20
    OD 6.84
    Desperado Rim, true beadlocks
    Rears they are wider than the fronts
    513 grams
    Stock Losi 5ive T
    Width 2.900
    OD 7.280
    621 grams
    note: the hub widths are different, Losi did this so you have to use their rims.
    No prob going to make some spacers, so I can use the ProLine rims, on the Losi hubs,
    about .100 thick...
    Losi
    .687 wide
    HPI / ProLine
    .580 wide
    15,025
  17. #137
    kansas
    7,835
    pic......
  18. #138
    Nov 2011
    Western Kentucky
    792
    You will not be disappointed they work top notch! Highly recommended no slop cure for sure. I'd also order one of these bad boys while your at it might as well wont raise the shipping charge helps keep the motor tight in place
  19. #139
    Jun 2009
    W Monroe, Louisiana
    1,995
    87GN please give us a mock up picture of the Bow Ties on all 4 corners!!!! That tire looks awesome just sitting there!!!!!!
    And I thought badlands looked good...
  20. #140
    114
    Brewers74, what is that motor brace/mount that bolts to the shock tower called??
  21. #141
    kansas
    7,835
    HPP Germany..
    http://www.hpp-germany.com/factory-s...6b14c54b78b10b
    Check on the motor mount mod a bit cheaper option...
  22. #142
    kansas
    7,835
    3.000 wide & 7.750 Tall, 1/5 Trenchers on the Losi Rims Dyed black. Left the rims in dye for three days while I was waiting for the tires to show~up. Might have to get a set of Trenchers for the Summit. Not going to run them on my Revo, to big..
    Org Trenchers on my Summit..
    ===next to a 3.8 Badland
    ===next to a Bow Tie
    ===Bow Ties
    16,752
  23. #143
    Nov 2011
    250
    Nice, loving the looks/mods you've done here. Really makes me consider trading or selling my FLM built EMBE and get a Revo.
    FLM EMBE, P4de "Digger", Slash MT, Rustler/P4de
  24. #144
    kansas
    7,835
    I had a FLM Maxx with custom alum skid & a few other thing I built. Hated it so much I never ran it, parted out & sold it all.
  25. #145
    Nov 2011
    250
    I'm thinking about doing the same thing. Between RPM arms, RPM mounts, RPM skids, FLM chassis/center dogbones, FLM ultimate hybrid bulks, MIP CVD's, Summit bumpers, Big Joes on Tech 5's, Trenchers on Axial 8 spokes, I could keep the Electronics and sell a pretty nice roller. Then buy a revo/summit roller and build that up. I'm just tired of the little things that seem to keep occurring over and over. Might put it up for sale, have to think about it. Already have Summit body that I've modified my EMBE to work with.
  26. #146
    Jan 2008
    Quebec Canada
    498
    Did you had prob breaking stub axel?
    I broke 2 stub in 5 min
    Need beefy stub for that mod
    3906 CC 1717 / MMM GA 7075 UE Khead LST2 DIFF
  27. #147
    kansas
    7,835
    The 1/5 Trenchers are for my converting to BL Losi 5ive T. Didn't want to wait on Traxxas any more to come out with a 1/5 off road truck. I'm not going to run them on my Revo, to heavy, I like my 3.8 Badlands. My buddy has a HPI Baja he has the 1/5 Badlands, looks like they might be a good fit. Still a little bit heavy for a 1/8 scale truck..
    I can see how the extra weight would stress the stub axels. Interesting set~up on your Maxx, looks good..
  28. #148
    Jun 2009
    W Monroe, Louisiana
    1,995
    So do u have any idea how the 1/5 bow ties perform without tape? Major balooning like badlands?
    Is there an 8mm bore 24mm Hex on the market to attatch to XXL losi stub axles?
  29. #149
    kansas
    7,835
    Quote Originally Posted by anr2442 View Post
    IDK haven't ran them & prob won't, prob going to sell them.
    IDK haven't seen anything, haven't been looking either. sorry...
    17,868
  30. #150
    Idaho
    1,206
    Why is the dog always in the picture lol
    Emaxx #3903, MERV
    RPM/PROLINE
  31. #151
    Long Beach, California
    6,397
    peggy (i think thats what the dog's name) is there as his signature, lol.
    | Rally GT8 Powered By CC |
  32. #152
    kansas
    7,835
    Figurines for (sizing & you know it's one of my pic). That is Frankie aka (Frances) my daughter has a minature dachshund, & Peggy the piggy next to Frances.
  33. #153
    Jul 2012
    Grand rapids michigan
    12
    pic......
    In this first picture, what tires are those in the center?
  34. #154
    Michigan
    399
    Youve got quite the wheel/tire collection.
    Big Air Don't Care
  35. #155
    kansas
    7,835
    You've got quite the wheel/tire collection.
    YEP.. never thought I would buy so many..
    how long did it take to build your summit/revo
    About two weeks, waiting for parts two months...lol
    Top pic L to R.
    Badlands on Geodes
    HPI Blast Spoke rim, Phaltline tire
    Talons on Geodes
    Geode rim 76 grams
    width 3.225
    OD 5.990
    width 2.750
    OD 5.950
    width 3.370
    OD 6.860
    HPI
    width 2.750
    OD 5.530
  36. #156
    24
    Nice build man. I just got mine up and running today. Summit cvds,2 speed tranny ( I only use one) , Summit bumpers, body mounts and body. Had it out on 4s with my new MMM setup and omg is it insane. I don't know how you guys handle 5/6s on these things rofl.
  37. #157
    kansas
    7,835
    just a little fun
    right 1515 ~ 2200kv & 1518 1800kv
    right 1515 ~ 2200kv & 1717 1580kv
    right 1515 ~ 2200kv & 2028 780kv 1/5 scale, does not fit in a Revo without major mod,
    18,853
  38. #158
    kansas
    7,835
    I think it's time to upgrade to Lunsford Titanium push rods. Don't know what I hit, but it was something. I have another set of Ti push rods, but they are for the LT rockers. SO... as you can see I bought a new set for the P2 rockers, new rod ends & hollow balls. The rods come with a zip tie cut to length for setting the rod ends lenght.
    P/N's Rods Lun2807 Rod ends Tra5348
    19,456
  39. #159
    Arkansas
    335
    So many motors!!! Ahhhhh!!!
    ERBE, MERV BB
  40. #160
    Jul 2012
    Eastern Iowa
    237
    19,456
    Hey 87 are the Lunsfords better than the Traxxas pushrods and turnbuckles???
    ERBE,MERV, Original T-maxx
