Results 1 to 12 of 12
    Jul 2011
    139
    Rear chassis brace
    How is the rear screw anchored when doing the chassis brace mod.I have read that people use a long screw and go through the chassis.After researching i still have a couple questions..
    What screw should i use and where can i get one?
    Does it need to be drilled and tapped?
    Thankyou
    Jul 2010
    England
    5,791
    As per the threads showing the mod, the rod is mounted to a little plate which bolts on top of the rear shock tower either need to make one ( T shaped ) or use the plate which comes with sway-bar kits usually. The other end of the rod is mounted to the body post assembly:
    http://traxxas.com/forums/showthread...its-finished!-)
    http://traxxas.com/forums/showthread...44#post4682544
    http://traxxas.com/forums/showthread...ds-for-bracing
    Should be more than enough pictures and info in those 3 threads hopefully.
    Jul 2011
    139
    i have the plate end sussed,im interested in how to anchor the rear(rear bumper end) .Is it a traxxas cap screw?What length?
    Jul 2010
    England
    5,791
    That's a minor detail- people use whatever seems to fit, juding by the pictures it looks like maybe an M4 ( 4mm ) screw would do the trick, long enough to anchor into the plastic properly; just have a dig in your spares box and see what you can find- a random screw that fits is all you need, it isnt a special item that has to be perfect.
    Improvisation =
    Jul 2011
    139
    4mm ok i'll have a go at it !Thanks for your input!
    cheers man
    Jun 2009
    W Monroe, Louisiana
    1,995
    I personally used the little blue (or red) spacers found on the pushrods with the m4 flat top screws. I pressed the blue spacer into the plastic rod end. The design of the flat head screw tightens up perfectly without slop.
    The reason i did this was bc the rod ends only accept m3 screws. Pop the metal ball out and the u make space for the larger m4 screw which will thread into the hollow hole on the rear brace.
    Jul 2011
    139
    The spacer on my pushrod is chrome.But i get your drift..thanks
    Jul 2010
    441
    i screwed the pushrods directly into the rear framing
    Jul 2011
    139
    Very nice! looks sick!
    kansas
    7,838
    ^^ 998 so do you have it figured out??
    Jul 2011
    139
    yea im all set just waiting for the postman.got some hardware from fleabay coming.I hate working on stuff and not having what i need.Thanks for the help you guys are alright!
    Get ready for the next onslaught of questions as im thinking about doing the aluminum tranny mod next
    cheers
    Feb 2009
    Pennsylvania.
    861
    You should make your plate out of stainless steal like I did with mine. I did it cuz I bent 2 alu. ones.
    JATO 3.3
    Stampede Build
    DeWalt 12v E-REVO on 4s
