Has anybody advanced the timing all the way up on there motors with the MMM esc ? I mean it say it will gain some power but make the motor run hotter.
Reason I am asking is because I am running a 1717 motor and she is running ice cold I mean barely over a 100 degrees and I just got the castle link and was thinking about advancing the timing.
Honestly she is running fine but I wanna see if I can notice a difference with timing advanced.
However, its not worth me messing up the motor even the slightest bit. If advancing the timing even causes the slightest damage over a period of time then I won't do it.
If there is no harm and all it does is make the motor run hotter than I will do it. Because my motor is running cold anyways a few degrees to play with.
Just up your gearing a bit.
