Results 1 to 18 of 18
    Jul 2011
    9
    T-maxx 3.3 running really rich
    I have a t-maxx 3.3 4908 model from 2009 that was just running really good one day and then it landed on its motor and its been running really rich since. Whenever you hit the throttle it will run really rich and boggy and spit out TONS of smoke for about 15 seconds and then just shut off. Its running so rich that you can tip the truck over after you ran it and oil will come out the tail pipe. We replaced the original carb and it made no difference. Me and my dad are at our wits end trying to fix it and he is a mechanic. We are going to try to air check it. We turned the high speed needle to 1 3/4 turns out and low speed to about 1 1/2 turns out in around 85 degrees F and 60% humidity.
    Thanks
    RC Turnbuckle Jr. tphill's Avatar
    Jan 2009
    Where I lay my head is home.
    3,276
    1 3/4 turns out from closed on the hsn is probably running a bit lean.
    Either you are the Predator or you are the prey
    Jul 2011
    9
    But its rich.
    RC Turnbuckle Jr. morganko's Avatar
    Southeastern Wisconsin
    3,494
    Quote Originally Posted by tphill View Post
    probably??? even I'd say that is waaaaaaaaay lean!
    "fat drunk and stupid is no way to go thru life"
    Jul 2011
    9
    Exactly but id say its normal running high speed is about 2 1/2.
    Jun 2011
    Rockville,Maryland
    77
    dude. i suggest you start from factory setting man. start by leaning them out by small turns. factory setting for Hsn is i think 4 turns out and Lsn is 2 turns out.My t maxx running weird right now. i don't know if it too rich like yours or too lean. after i start it and idle for 5 seconds, it did a wheelie on the grass and died in 10-15 seconds. it have a lot(not like a lot) of blue smoke. then i saw some smoke coming out maybe from the engine i am sure. the cooling head was pretty hot(not that hot). i tried to put just a little of water and it didn't evaporate.
    Jul 2011
    9
    But its rich
    Jun 2011
    Michigan
    704
    why do you think its rich? bad performance? because that can be a sign of too lean too
    16
    are you thinking it rich because of the excessive exhaust smoke and fuel from exhaust? is glow plug ok? I have been running mine t-maxx's on outdoor track in 85-90 degree air and am waaaaay richer on hsn than you are. about 3 1/2 on my 3.3. dont forget the basics here. set lsn and hsn to default then look for other problems that could be causing your concern. I have chased my tail with lsn/hsn settings to find out I had other issues instead. I did have a "bad" glow plug cause stalling concerns even though it would light up the light on my eazy-start. installed new glow plug, ran great.
    Jul 2011
    9
    If it was lean would it be spitting tons of smoke and enough oil to squirt out the end of the pipe.
    Jul 2011
    9
    Quote Originally Posted by mxzman View Post
    Ive used MANY glow plugs from different brands it doesnt change it.
    Jun 2011
    Michigan
    704
    you're mixing up lean and rich. Rich is when the engine has an excess amount of fuel coming into it. It will have blue smoke and fuel spitting out of the exhaust. Lean means the engine isn't getting enough fuel. When you turn the needle counter-clockwise, you are making the opening that the fuel flows through bigger. The factory setting are rich, which means that the needles are allowing more fuel to go into the engine than necessary. When you start tuning it, you turn the needle clockwise to allow less fuel into the engine. Engines run better with less fuel until they get to a point where they aren't getting enough and start to overheat and lose power.
    Quote Originally Posted by tmaxx101399 View Post
    Jul 2011
    9
    Quote Originally Posted by rcdriver5 View Post
    No i dont have them mixed up i know what lean and rich are ive had it for 3 years and it blew up once and ive never had a problem until now.
    Nova Scotia (Eh!)
    422
    Maybe your HSN is very rich and your LSN is really lean?
    back
    Jul 2011
    9
    Quote Originally Posted by maxidodies View Post
    What do you think the settings should be?
    Jun 2011
    Rockville,Maryland
    77
    I don't want you to hurt your engine man, thats why i told you start factory setting and start leaning it.
    my Hsn is actually 3 and 3/4 turns from out and about 2 turns out for the Lsn maybe? try that.
    Jul 2011
    9
    Quote Originally Posted by pantat7 View Post
    I would do this but its already rich and i dont know why.
    Jun 2011
    Rockville,Maryland
    77
    Dang man. Take it to your local hobby shop and let them take a look at them. Thats the best you can do i guess.
