Results 1 to 3 of 3
    Jul 2011
    16
    Alternative diff shims ?
    Apologies if this has been posted before, I've searched but found nothing ...
    Does anyone know if there are alternative shims to the Associated 21141's which will fit a merv diff ? I'm having trouble sourcing some quickly in the UK at the moment
    The Associated ones are .324 x .409 x .005 , which translates to 8.23 x 10.4 x 0.125mm. I've found a couple of alternative sets which include 8x10mm shims and was wondering if they would fit ?
    One is Kyosho part 96644 (e.g from here which contains a selection of 8x10mm shims in varying thicknesses
    Jul 2011
    16
    Ok, I know its bad form to reply to my own thread ... but I have an update which might help someone
    I finally managed to get some Associated 21141 shims but also bought some standard 8x10mm shims as well and I found that they fit perfectly, which is probably because the diff bearing (part #7020) is 8x12mm. The only problem was the ones I bought were 0.3mm thick, which turned out to be too much; next time I'll buy 0.1mm ones.
    So, if you're having problems locating some AE shims just get some 8x10x0.1mm ones instead and you should be ok
    Jan 2010
    Wales. Uk
    741
    I shimmed with one loop of a spring. It was the perfect thickness so I cut off a perfect circle and installed it. It's performing amazingly with no clicking or binding. I bought a huge box of springs from aldi for 3.50.
    Signature removed due to excess awesomeness.
