I guess I never did say....
Its an 800kv 42x58 mm outrunner by *******, on 6s.
For me at least, the ERBE with the MMM was my first 4 pole motor. It felt so smooth compared to the 2 pole setups I had used in the Slash.
Well the outrunner is 14 poles.
That means you can control it at much lower rpms than motors with fewer poles, thus the ability to crawl. Plus the ability to put down precise amounts of torque. Like you can go up a steep hill, stop and then continue. On the stock motor the glitch from starting from a stop usually makes it just wheelie over if its on a steep hill already.
In a way, it feels like a tractor. It can be really slow, and yet still push really hard with control. Or better yet, it FEELS like a brushed motor.
But I'm still having trouble getting it to be reliable. After sorta gluing the magnets I went to an open field. I blasted around at full throttle quite a bit as some endurance testing. 10 minutes into the run, I got the crazy vibration back again.
I took the motor apart, and the can keeps touching the stator. This pic was taken earlier, but you can see the slight rubbing on the magnets at the open end of the can already. I'm not sure how, the whole thing might be flexing. I just can't keep it running on 6s geared tall enough to be fun. Another option might be to gear it silly tall, like for 50 mph or so. That would really help keep the rpms low.
