Results 1 to 24 of 24
Thread: Tacon 1/8 Motor
    188
    Tacon 1/8 Motor
    Does anyone know if this motor will fit the Slash 4x4 without modifications and if it will work with the stock VXL ESC?
    Tacon 3674-540XL-6T Brushless Motor 2800KV
    http://www.hobbypartz.com/96m214-3674-2800kv-6t.html
    Lilydale, Victoria, Australia
    2,845
    Motor will fit without modifications
    Stock ESC will not run it well as it has 4 poles
    Cheers
    Slash Platinum
    RC Turnbuckle Jr. asheck's Avatar
    Nov 2007
    Kansas City
    7,361
    The 36 series motors are 2-poles. The VXL will run it, just might have heat issues when pushed. If you added an external bec, and a fan, it should do pretty good on 3s.
    _
    _
    _ 3 lines are all that's allowed in a sig.
    2,845
    Pretty sure they are clones of the Leopard 4 poles mate
    http://www.leopardhobby.com/product/...ionID=01020203
    Cheers
    Slash Platinum
    188
    That's what I was concerned with regarding the 4 pole motors. I couldn't tell on the specs if this Tacon is 4 pole or not...
    Edit, I think you're right, crusey. It looks like that motor is 4-pole. thanks for the heads up
    May 2010
    847
    Quote Originally Posted by hailjack View Post
    Hobbypartz told me it was a 6-pole but I haven't taken mine apart to verify this.
    Had-> MERV, ERBE, Stampede 4x4
    Nov 2007
    Kansas City
    7,361
    It's possible I am wrong, more probable I'm right, but I will admit to the possibilty.
    If you look at all the other Tacon motors that are 4-pole they are listed as 1y , 2d, ect. and have the flexible wires coming out of them, as does the Leopard 3674. This looks just like, and is listed just like, all the other 2-pole motors, kv only. Plus look at the wattage difference between the Leopard 4-pole 2400 watts , and the Tacon 1580 watts. But the Leopard 3674 2-pole is listed as 1500 watts. So going by these things, my money is on 2-pole.
    Fact is, I don't really know, and have not been able to get a definitive answer.
    _
    _
    May 2010
    847
    Not saying I'm right either, just reporting what they told me
    All I can say for sure it the Tacon 2800kv is just as fast as my Castle 2400kv 4-pole motor
    Quote Originally Posted by asheck View Post
    Nov 2007
    Kansas City
    7,361
    Yeah, I'd be hard pressed to believe someone from Hobbypartz, knows exactly what's up with everything But again, I must admit to the possibility that I'm wrong.
    There's also the weight. The 4-pole Leopard weighs 315 grams, The 2-pole Leopard is listed as 370 grams , and the Tacon is listed as 370grams. Most Tacon and Leopard motors share the same specs. Other then speculation, I have yet to see anything showing that it's a 4-pole.
    The VXL is just as fast as my Castle 2400, when they are geared for the same speed.
    That just isn't the whole story, though.
    I have been very happy with Tacon motors, and bought the Tacon 2150 4074 4-pole to test against the Castle 1515 2200 , in my E-revo. Using the same gearing, they were within .5mph of each other, like 48 - 48.5 mph, and the Tacon was not that much warmer after a full bash session with that gearing, like 5-10* . Very impressive, IMO.
    _
    _
    May 2010
    847
    Here's a video of a lower kv version (1900kv) of the same Tacon motor in a Stampede 4x4 if you didn't see it already.
    http://www.youtube.com/UltimateRCnet.../4/OIQ0m1BTfYo
    188
    OK-so assuming it's a 2-pole, would I see any benefits of running it with the VXL ESC on 2S SPC Lipo? Keep in mind that I'll be converting it to a MT with 4.87" Trenchers soon so I'll be looking for low heat and high torque.
    Assuming it's a 4 pole, what then happens to the VXL ESC? Will it just fry?
    Nov 2007
    Kansas City
    7,361
    The motor will run cooler then a VXL motor, for sure. But it will also draw more amps, especially with the Trenchers, on 2s, so I would expect the esc to run hotter.
    A 4-pole just doesn't seem to run right with the VXL, but I haven't heard of it frying the esc.
    _
    _
    May 2010
    847
    2800 Dissected
    Dunno...2-Pole?
    Nov 2007
    Kansas City
    7,361
    You can't really tell by looking, atleast I can't. The key is the rotor. Does it just have north and south, or is there north and south twice. You could tell with another magnet.
    _
    _
    188
    Wow, so we've cracked this thing open and still can't tell?
    Castle Valley UT and Santa Barbara CA
    706
    According to the Traxxas specs, the ESC could barely, just barely, manage that motor. But it runs hot enough with the VXL, so I would say go with a 1/8 ESC if you are going to use that motor.
    Brushless Summit!!!!!
    Slash 4x4
    May 2010
    847
    99% sure it's a 2-pole motor.
    Texas
    101
    I recently install a Tacon 1700 3674 motor I had laying around with the VXL-3s esc in my 4x4. I am running the 50t spur with a 26t pinion. The motor runs very cool but the esc went into thermal after about 15-20 mins on a 3s run. This was a little longer run time than running a 11t pinion/54t spur on the stock setup(which on 3s, runs hot!!). Will a small pinion gear only help the motor run cooler or will the esc run cooler too. I am trying to find a cooler solution before I go out and buy a MMP 2400 combo.
    Rusty VXl
    Spartan
    HPI Sprint2 VXL
    Slash 4x4 PE
    May 2010
    847
    Quote Originally Posted by dmwilson09 View Post
    My experience has been smaller pinions make my motor run warmer and my ESC cooler and vice versa.
    Nov 2007
    Kansas City
    7,361
    Like I stated earlier, running an external BEC, http://www3.towerhobbies.com/cgi-bin...?&I=LXWNS2&P=7 and a fan http://www3.towerhobbies.com/cgi-bin...&I=LXSGV1&P=ML will allow a little more breathing room for the VXL, I would say 20-30* . Adding an extra cap wouldn't hurt , either.
    _
    _
    319
    Quote Originally Posted by crusey View Post
    Cheers
    This motor WILL NOT fit without modifications... you need to trim some stuff off the chassis and shaft cover. Mine just arrived today
    Vacaville, CA
    25
    According to the specs on the link the OP gave it states 6T/2P. 6 turns. 2 pole
    Revo OS 21TM, ERBE, SLASH 4X4, RAIL
    Sep 2010
    the giant boot. Anybody?
    2,727
    SPEC'S,
    code 96m214-3674-2800kv-6t
    Net Weight (g) 370
    Watts 1600
    Outer Diameter?mm) 35.8
    Length (mm) 74
    Stator 45MM
    No of cells (lipo) 3
    max efficiency (%) 85%-89%
    max efficiency current 110
    no load current (A)/7.4V 5.4
    Internal Resistance (mohm) 0.0047
    Shaft Diameter (mm) 5.0MM
    Shaft Length (mm) 16
    KV (RPM/VOLT) 2800
    Turns (for cars)Poles 6T/2POLES~~~~~~~~~~~~~~~~~~~~~~~~~~~~2 pole's.
    Max Voltage 12.6
    Wire Size 0.34
    Bullet Connectors YES
    Bullet Connector Size 4.0MM
    design for FSD
    319
    Quote Originally Posted by blazer View Post
    Sorry thought i was in the stampede 4x4 section. This motor will fit.
