Results 1 to 14 of 14
    52
    Merv big block body???
    what is everybody using for a body to fit there merv with a big block setup? im kinda wanting a proline slipstream body, but didnt know if it will fit because the motor sticks up more.
    Connecticut
    2,332
    Nope, a slipstream won't work, you'll have to cut it. Get a Baja Bug body or stick to the stock one.
    Just accelerate, and only good will come.
    52
    gotcha.. thanks. they need to come out with some different bodies for the merv..
    RC Turnbuckle Jr. RC-Fan's Avatar
    Jun 2010
    Miami, Fl
    6,517
    I'm using the stock, also the bug body has plenty of room.
    FLM - EMAXX
    St. Louis, MI
    8,185
    Slipstream fits with a lot of dremel work... there is not much left of the back end when you finally have enough clearance. lol
    I see a big hole in the body market... just waiting for some manufacturer to step up to the plate and make money.
    The bug body is pretty cool... it is just round enough that it will flip you back on your wheels just about every time. (from what I have read, anyway... the bug body is my first aftermarket body I am going to order)
    52
    i talked to a guy a proline and said they should have more bodies for the merv and he said they r working on it.. i said i would like to have like the silverado truck and the gmc topkick body for the merv, that they already make for the full size revo. so who knows if it will happen but we will see i guess
    52
    well i ordered a proline bug body today and i guess will have to wait for them to make something else. thanks for the advice
    Jun 2010
    Miami, Fl
    6,517
    You will like it, it's a nice body
    FLM - EMAXX
    West Bend, Wisconsin
    210
    The Slip stream works great, and you barely loose anything when you cut it. No dremel required either. An exacto knife and lexan scissors are all that is required. Take a look.
    I traced the back of the motor can onto a piece of sheet styrene, then added 1/16th of an inch all around for clearence. Once I had a perfect circle, I held it to the inside of the body and scribed around it from the outside. As you can see, it worked perfectly. It only added 15 minutes to the total trim time. But I rather enjoy the results.
    For reference, here is a slipstream without the big block.
    St. Louis, MI
    8,185
    Of course the dremel is not required to do lexan work... it just makes it easier!
    You did a spectacular job!
    I was referring to a hack job compared to yours... the whole "bowl" area was totally removed.
    Jun 2010
    Miami, Fl
    6,517
    Looking good maus, definitely the slip will be next on my list.
    FLM - EMAXX
    Manhattan, KS
    68
    Wow that looks great, Maus. I didn't go into detail when I carved mine out. I just cut the whole back area out haha. Laziness?
    I may steal your cutout design when I get my new slipstream painted. Looks 10x better.
    210
    Quote Originally Posted by Jacob.T. View Post
    Feel free to use my design. Just be aware that the motor is not mounted on the center axis of the car.
    St. Louis, MI
    8,185
    Even Jacob's cutout was better than the hack job I saw... lol
    Now if I could just find it....
