+ Reply to Thread
Thread: Shock Question
    Jun 2010
    New Hampshire
    264
    Shock Question
    The black circle (piston?) that goes between the e-clips what does it do? I also have ones with 1 and 3 holes in them, whats would they do if I put them in my truck? I would like to make my shocks stiffer so my truck doesn't sag as much would these help or should I buy Losi green springs?
    Thanks,
    Slashbasher24
    "Duct tape and superglue are my spareparts"
    Wisconsin
    1,565
    The pistons in the shock have 2 holes. If you change them out, the fluid will be a ble to make quicker to the other side so it changes the way the shock feels. i don't think they would make it stiffer. If anything, it would be softer.
    Land of the free?
    Edmonton, AB (and looking for an RC buddy. PM me if you're from NE Edmonton!)
    392
    Fewer holes in the piston will make the shock react slower, and vise versa. If you're trying to reduce sag, stiffer springs are your only option. Try adding some pre-load spacers if you haven't already.
    Jun 2010
    New Hampshire
    264
    zball94: I have 16mm of preload with 50wt oil in the shocks and my truck sags alot
    MotorStuff: thanks for the clarification would the 3 hole make the shock rebound faster?
    Wisconsin
    1,565
    ^^ Yes, thats right.
    Land of the free?
    Dec 2001
    Dallas, TX
    664
    Using a piston with more holes is the same as using a lighter shock oil.
    Using a piston with less holes is the same as using heavier shock oil.
    Your rebound also depends on your springs. That's why it is important to match your oil with the shock springs.
    If you want to reduce sag or increase the ride height, you need stiff springs. Losi Green or Blue should work well.
