+ Reply to Thread
Thread: motor problems
    red deer alberta
    464
    motor problems
    on my Merv the motor is sound realy weird when its slowing down but not when it is accelerating. in runs fine the noise sounds like it needs to be oiled or something is there motor oil you can put in it and would it help.
    UK
    1,936
    is it the vxl 3m system? If so a drop of 3 in 1 or light bearing oil on either end where the bearings are is recommended every month or two. And does it slow down very quickly? because if so check your gear mesh it will be too tight in that case get a strip of paper place it inbetween the gears and tighten fully then pull it out
    Does more $ = More fun?
    Rustler VXL
    red deer alberta
    464
    its stock system its slows down normal
    UK
    1,936
    try adjusting the gear mesh anyway cus i don't see what else could be the problem
    Rustler VXL
    red deer alberta
    464
    i ajusted the gear mesh nothing helped do i need a new motor
    Connecticut
    2,332
    Is it when it's moving, but not with power from the motor, like coasting? Do you hear the noise then?
    Just accelerate, and only good will come.
    UK
    1,936
    not necessarily do you notice a decrease in performance or increased temperatures?
    Actually if it's just making a weird sound remove the motor and try and move the shaft from side to side there should be extremely little play if you can do it easily you need a new motor
    Rustler VXL
    red deer alberta
    464
    theres no play and its been a bit warmer that usual
    UK
    1,936
    have you changed your setup recently gearing battery etc?
    Rustler VXL
