    38
    RPM Axle Carriers need help with install
    How do you remove the nut on the end that allows the bearing etc to be released on the axles
    TX
    578
    Use a screw driver or knife and pry it off, don't twist it or anything just straight off. Took me a few minutes to figure it out myself so hope this helps.
    Rally SV2/4600 and fully loaded
    52
    it also took me a while to figure this one out. flat head screw driver worked in the end
    38
    PRO tips guys srry I didnt get back sooner was out in a the parking garage tearing it up :P... Flat head screw driver does the trick simple install from there thanks again for the tips
