Results 1 to 2 of 2
    38
    2 day old KB has a Close one !!!!
    So I was high speed drifting...when sliding to the left ( I drift around a light pole) I heard the worse noise followed by a scraping of plastic. I connected the front of the car with the pole and somehow the drive shaft and the connecting ball joint arms popped off and i was left with just the swing arm holding the front left tire . Wheel was stuffed in the wheel well, I used the blue prints given with the model was able fix it up in about 45 mins. I feel lucky nothing broke. just came apart, are they meant to do that on impact ?
    38
    Did some looking around... the knuckle is what did me in just ordered upgraded set from RPM, should fix the problem if anyone else runs into it
