Results 1 to 16 of 16
    Aug 2008
    Jackson, NJ
    423
    550 Brushless Motor in 2WD Slash
    I have seen many new 550 brushless motors popping up on the market. Are they really necessary for a 2WD Slash? I can see needing them for a 4WD due to all of the extra drivetrain, but what would it accomplish for a 2WD? Are there any advantages?
    RCM Rustler
    MM Slash
    Sidewinder 'Pede
    Springfield, MO
    3,681
    I run a 550... its just a very powerful setup.
    NJ
    158
    I was under the impression, that you can run 550motors in2wd, but they are really meant for 4wd.
    But, You can run anything in anything if you really want to....LOL
    The SERVO i just got is a MONSTER truck/helicopter/airplane SERVO, but im running in my 2wd SLASH....LOL
    THX
    2wd Slash MMP/3800kv/Savox1258tg
    Feb 2008
    SoCal, USA!!
    728
    Run whatever motor (or servo) you want. Just adjust your TX/ESC/driving style accordingly. If I can drive around with this motor in mine, a 550 should be no problem for you.
    417
    Quote Originally Posted by Dr. Isotope View Post
    which tacon is that i have the 2150kv also what gearing and lipo do you have
    EMAXX 1480kv 6s
    RUSTLER 2150KV 4S
    Castle Valley UT and Santa Barbara CA
    706
    What motor is that?
    And a 550 motor should fit. The +10 on the size over the stock ones seems to only be length.
    Brushless Summit!!!!!
    Slash 4x4
    Springfield, MO
    3,681
    Quote Originally Posted by zanek View Post
    What motor is that?
    Yep. 36mm is a very common diameter for motors, most 540/550's are 36 around, meaning they'll fit in the Slash.
    The one I run is 10 mm longer than a typical 540 size motor at 60mm. There are 72mm long motors also, although as you add length, you lower kv... (typically).
    Apr 2013
    What kind modications you need to do, if you put 550 sized or 4-pole 540 motor to slash?
    Those holes in engine are bigger thread than stock can do use..
    RC Turnbuckle Jr. rjm2519's Avatar
    Feb 2008
    Fl
    3,062
    550 motors use the same mounting holes as the stock motor, as it is also a 550 motor. The vxl motor is actually an oversized 540 motor so having a regular sized 550 brushless would probably not be much different in terms of power.
    Don’t handicap children by making life easy
    Grassie Ontario Canada
    3,136
    Quote Originally Posted by rjm2519 View Post
    No I disagree..
    Vxl is 2 pole
    Most 550 motors are 4 pole
    15,683
    Quote Originally Posted by kdvanb View Post
    No I disagree..
    Vxl is 2 pole
    Mine is not.
    Re. 550 2-pole motor motors, this is why they exist:
    Quote Originally Posted by ROAR Rules
    550 4X4 Short Course Motor Specifications
    Thursday, June 23rd, 2011
    Please note that these are specifications for 550 motors that are only legal in the 4X4 Short Course Category.
    8.8.6 10th scale 4×4 Short Course Truck (SCT) 550 Motor
    8.8.6.3 Rotor:
    External shaft diameter may be either 0.125 inches (3.175mm) or 0.197 inches (5mm). Only one piece, two pole Neodymium sintered, or Ferrite (Ceramic) magnetic rotors are permitted. The magnet length shall be a minimum of 39.0mm and maximum of 46.0mm not including any nonmagnetic balancing material. The magnet outside diameter shall have a minimum of 12.3mm and a maximum of 14.0mm, no tolerance, for the entire length of the magnet.
    Alt-248 on the number pad = °
    3,136
    Mine is not.
    That's why I said most..
    15,683
    Got a count?
    3,136
    I'm confused..
    15,683
    I'm confused..
    Do you have a count or a list of 2-pole vs 4-pole 550 motors? If so, is there also a break-down of sensored vs sensorless?
    If you don't, it doesn't mean your observation and assertion about the greater number of 4-poles is wrong, but it is harder to prove.
    3,136
    Oh..
    I get it now..
    I didn't mean it like that..
