    Aug 2010
    Portugal
    241
    Wink What wire is positive and negative? 380 motor
    i found this image but didn't help.. so what wire is positive and what the negative in THE MOTOR?
    [IMG]
    Thank you
    MERV
    Jun 2010
    Miami, Fl
    6,731
    on the motor it doesn't matter
    Aug 2010
    Portugal
    241
    no? uhm.. i'm soldering the 4mm bullet connectors to fit in the sidewinder v2.. so it doesn't really matter ?
    MERV
    Jun 2010
    Miami, Fl
    6,731
    nop,it won't matter if the motor goes into reverse when pulling the throtle just switch wires.
    Aug 2010
    Portugal
    241
    Ok, thank you very
    MERV
    16,000
    RC-Fan is correct - it does not matter.
    What you should try to do is to get the wires as even in length as possible.
    Alt-248 on the number pad =
    Aug 2010
    Portugal
    241
    YES, i didn't cut nothing.. i just unsolder the old ones and resolder the 4mm castle creations bullet connects
    The bullets
    [URL=http://imageshack.us/photo/my-images/339/img1240j.jpg/]
    The finish product
    [URL=http://imageshack.us/photo/my-images/41/img1242b.jpg/]
    Compare the old 3.5mm bullet connect to the 4mm from castle creations.. the 3.5mm are really small.
    [URL=http://imageshack.us/photo/my-images/714/img1248qt.jpg/]
    MERV
    Sep 2009
    Lancashire - UK
    656
    Did you notice the hex screw in your motor is loose ? Also the 3 wires are neither +/- if the motor goes the wrong way just swap any 2 wires.
    MERV│
    MAMBA MAX
    Aug 2010
    Portugal
    241
    Yes, i've open my motor to replace the bearings and its not fully closed yet.. and yes if the motor goes reverse i'll swap the wires until i get the right direction
    Thank you
    MERV
