Thread: drive shaft
    82
    drive shaft
    I snapped my rear drive shaft. how do you get it out i removed the lower cover but cant get it out is their some trick or set screw?
    TX
    578
    Set screw on each side should do the trick
    Rally SV2/4600 and fully loaded
    Bay Area, CA
    438
    Yup, two screws... Remove set screw in U joint at transmission and you'll also need to pull off the rear diff/skid plate to get to the rear U joint set screw.
    The prototype project.
    82
    Thank you for the help the plastic filled in the hole on the set screw.
