    Castle Valley UT and Santa Barbara CA
    706
    Gear ratio calculation
    Today I stripped the stock 54 tooth spur gear. I am currently running the stock 13 tooth pinion also. I have a 12 tooth pinion gear, and 50 and 52 tooth spur gears. Which spur gear should I use with the 12 tooth pinion to get the closest gear ratio to stock?
    Thanks, Zane
    Brushless Summit!!!!!
    Slash 4x4
    SoCal
    77
    The 50 spur with the 12 pinion will be close. The stock ratio is 4.153 and the new ratio is 4.166. Pretty close.
    Slash 4x4:
    Takes a lickin' & keeps on tickin'!
    706
    Okay. thank you
    Slash 4x4
    SoCal
    77
    No problem. Pretty easy to calculate.
    Just divide the spur teeth with the pinion teeth.
    Stock = 54/13 or 4.153.
    52/12 = 4.333
    50/12 = 4.167
    The 50/12 combo is the closest to stock.
    Slash 4x4:
